Buffalo NY to Grand Rapids, Minnesota
1081 loaded miles
On the way!
Don't forget the GPS
1081 loaded miles
On the way!
Yeah, I can save a bit of money doing it myself. Figured I'd better be safe than sorry and bring the van in for a checkup. I was assuming that if it was the wheel bearings they would have broke somewhere between Louisville and Columbus. Mechanic is still looking at it....makes me nervous since he hasn't called. I'd do this at home if I had the right tools.chances are a "squealing" is the brake pad "wear indicator" it hits the rotor when the brake is applied and sometimes when the wheel is "side loaded" as when turning...thats when you need to change the pads, before they are wore bad enough to tear up the rotors...and on top of that, wheel bearing don't often "squeal"...they grind....its good you are having it looked at now...BUT...think of how much money you could save if you were doing these repairs / maintainance yourself...hanging a set of brake pads is a cake job....
I think you read books alot, buy a "chilton manual" for you van, you can read , chances are you could do alot of stuff (not all but alot) yourself....
Slow as hell down there. I sat for almost a week last time I was down that way. I think they are more concerned about cleaning up the tornado damage down there towards Cleveland, TN than shipping anything....LOLKnoxville TN one run last week one run this week so far and its Thur. BS.
Get me moving now.
Do not lock me. if you dont got a load Its in the Notes.
I run wide open and take Both Surface and WG.
now get me moving.
Not by much!!!!Get me moving now!!!!!!!!!!!!!!
If i was in louisville you would have me dh out for a semi good load. Maybe ill just dh to scranton pa
at least its cooler.
