Murraycroexp
the poster quoted taking 5500 lbs in a cube van
Never seen a cube that weighed 4500 pounds or less. Just sayin.
that was the other posters point....Is he? or just taking heavy under the table?....O! My bad ya idk what kind of cube that is must be over 10K to carry that much payload.. So he is logging
You do if the vehicle ever weighs more than 10,000 pounds.You don't have to log if GVW is under 10000...
I've done a go catch the overflow, 2 vans, first one loads all he can and I get the overflow, in this case it was 2 10 pound boxes. And off to Charlotte we went.I've done double call out loads... 2 sprinters 3 skids each... About 4-5 times... Don't know the reasons or circumstances not my concern only the $$$$ matter
I run a cube van just to confuse every on, if the load calls for cv the shipper is happy if it call for a dock high ST I back onto blocks PLUS I can carry 5500lbs some of the brokers don't have any clue what there doing
Ok but if your GVWR is under 10K why would u weight more then 10K? Unless towing or something .You do if the vehicle ever weighs more than 10,000 pounds.
The rules are for the GVWR or the actual weight.
This can't be a picture of Ovm .... he does Not take overweight loads ....lol..
If your GVWR is, say, 9999 pounds, and you are 300 pounds overweight, they're ya go.Ok but if your GVWR is under 10K why would u weight more then 10K? Unless towing or something .
True but even if u slap a sticker on the side door that says 10k.. It shows on the registration the true GVWR... So that doesn't work...If your GVWR is, say, 9999 pounds, and you are 300 pounds overweight, they're ya go.
Also, a lot of these cube vans are rated at 12,500 pounds, give it take, and the owner slaps 10,000 GVWR on the side doors in order to avoid logging. But they continue to run over 10,000 pounds all the time. If they get caught, it's serious money.
Tell that to the scores of fake-labeled cube vans who illegally and routinely run without logs.True but even if u slap a sticker on the side door that says 10k.. It shows on the registration the true GVWR... So that doesn't work...
I get what u are saying....Tell that to the scores of fake-labeled cube vans who illegally and routinely run without logs.
Dang, for 35- 40k, I'd rather just get a local gig and be home every night ( Oh wait, .......).
Don't get me wrong, I enjoy going OTR. However, with that said, I don't go very often. Most of my loads are out and back.Yeah but ive never been over the road before. Im kind of excited about it. Its also possible that I will hate it and adopt the same opinion as you just stated.
I'm pretty sure "dually" isn't mentioned in the definitions of Commercial Motor Vehicle.
