SPECS FOUND it's a long list folks
i have 4 different models here so this is a bit long.
dodge of naperville.com
2007 for the 2500 170wb.
Cargo Capacity Max (cubic feet): 547
Curb Weight (pounds): 5399
Length (inches): 289
Luggage Capacity (cubic feet): 547
Maximum Seating: 2
Payload Max (pounds): 3451
Towing Capacity Max (pounds): 5000
WheelBase (inches): 170
MechanicalAspiration: turbodiesel
Axle Ratio: 4.1
Block Configuration: VCam Type: double overhead camshaft
Cylinder Quantity: 6
Displacement (liters): 3
Engine Type: diesel
Fuel Capacity (gallons): 25
Horsepower: 154Horsepower At (RPM): 3400
Torque: 280
Valve Quantity: 24
[Drivetrain] Axle ratio: 4.10
[Drivetrain] Driven Wheels: rear wheel drive
[Spare Tire] Mount Location: underbody
[Spare Tire] Size: fullsize matching
[Spare Wheel] Rim type: steel
[Suspension] Front Arm Type: Being Researched
[Suspension] Front Spring Type: coil springs
[Suspension] Front Stabilizer Bar: stabilizer bar
[Suspension] Front Suspension Classification: independent
[Suspension] Front suspension type: MacPherson strut
[Suspension] Front Suspension Type: MacPherson struts
[Suspension] Independent: front
[Suspension] Rear Arm Type: Being Researched
[Suspension] Rear Spring Type: leaf springs
[Suspension] Rear Stabilizer Bar: stabilizer bar
[Suspension] Rear Suspension Classification: solid axle
[Suspension] Rear Suspension Type: solid axle
[Suspension] Rear Suspension type: torsion beam
[Suspension] stabilizer bar: front and rear
[Tires] Diameter: 16
[Tires] Prefix: LT
[Tires] Profile: 75
[Tires] Speed Rating: Being Researched
[Tires] Tire Pressure Monitoring System: tire pressure monitoring
[Tires] Type: all season
[Tires] Width: 245
[Towing and Hauling] Cargo tie downs
[Towing and Hauling] Tow Hooks: front
[Transmission] Automatic type: Shiftable automatic
[Transmission] Manual / automatic: Automatic
[Transmission] Number of speeds: 5
[Truck Features] Auxilliary transmission cooler: auxiliary transmission fluid cooler
[Weights and Capacities] Manufacturer's 0-100km acceleration time (seconds): Being Researched
[Weights and Capacities] Manufacturer's 0-60mph acceleration time (seconds): Being Researched
[Wheels] Diameter: 16
[Wheels] Rim Type: steel
[Wheels] Width: 6.5
Safety
[ABS Brakes] ABS: 4-wheel ABS
[Brakes] Braking assist
[Brakes] Electronic Brakeforce Distribution
[Brakes] Front brake diameter: 10.7
[Brakes] Front brake width: 3
[Brakes] Front brakes: ventilated disc
[Brakes] Rear brake diameter: 10.7
[Brakes] Rear brake width: 3.7
[Brakes] Rear brakes: disc
[Crash Test and Other Ratings] Head Restraint Test Rating (IIHS): Not Tested
[Seatbelts] Seatbelt pretensioners: front
[Stability and Traction] Stability control
[Stability and Traction] Traction control
Exterior
[Doors] Rear door type: barn
[Doors] Side door type: manual sliding side door
[Mirrors] Driver mirror adjustment: manual
[Mirrors] Passenger mirror adjustment: manual
[Mirrors] Signal mirrors: turn signal in mirrors
[Roof] Roof rack
Interior
[Air Conditioning] Front air conditioning zones: single
[Air Conditioning] Front air conditioning: automatic climate control
[Audio System] CD-controller
[Audio System] In-Dash CD: single CD player
[Audio System] Radio: AM/FM
[Audio System] Total Number of Speakers: 5
[Comfort Features] Cargo area light
[Convenience Features] Center Console: front console with storage
[Convenience Features] Cupholders: front
[Convenience Features] Door pockets: front
[Convenience Features] Front Power outlet: 12V
[Convenience Features] Overhead console: overhead console with storage
[Convenience Features] Power steering
[Convenience Features] Seatback storage: Being Researched
[Convenience Features] Steering wheel: tilt and telescopic
[Driver Seat] Manual Adjustments: Being Researched
[Headrests] Adjustable Front Headrests: height adjustable headrests
[Headrests] Number of Front Headrests: 2
[Instrumentation] Clock
[Instrumentation] Compass
[Instrumentation] External temp: external temperature display
[Instrumentation] Low fuel level
[Instrumentation] Tachometer
[Locks] 2-Stage unlocking: Being Researched
[Locks] Power door locks: remote power door locks
[Passenger Seat] Manual Adjustments: Being Researched
[Seats] Front seat type: bucket
[Seats] Upholstery: cloth
Mechanical
Engine Type: diesel
Valve Quantity: 24
Horsepower: 154
Torque: 280
Axle Ratio: 4.1
Capacity/Dimensions
Maximum Seating: 2
Safety
Crash Offset: Not Tested
Passenger Crash Grade: Not Tested
Rollover Resistance Rating: Not Tested
Side Impact Crash Test: Not Tested
Side Impact Crash Test Front: Not Tested
Side Impact Crash Test Rear: Not Tested
2-ADDN KEYS
3.5L V6 GAS ENG
5-SPD AT
CARGO PARTITION PROVS
INSULATING WNDSHLD W/FILT BAND
PARAMETRIC SPEC MOD
REFLECTING TRIANGLE
Factory Installed Options
Supplemental Front Seat Side Airbags
Supplemental Side Curtain Front Airbags
Side Front Driver Airbag
Daytime Running Headlamps
Security Alarm
Parksense Front and Rear Back-Up System
Rear BackUp Alarm
Cell Phone Prep Wiring
3.92 Axle Ratio
5.10 Axle Ratio
220 Amp Alternator
95 Amp Battery Deep Discharge
Cargo Lashing Straps
Wood Floor Delete
Wood Floor Less Partition Wall Delete
Right Sliding Door Delete
Rearview Mirror Delete
Additional Keys
Two Stage Sliding Door Interlock
Front Auxiliary Heater
Auxiliary Belt Drive for Compressor
Anchoring Lugs Delete
Light and Rain Sensor
Adjustable Idle Control
Radio Prep
Antenna for GSM, GPS, UMTS Network
Wheel Chocks
Rear Back-Up Camera Prep
Puncture Sealant and Portable Air Compressor
Auxiliary Heat Exchanger Prep
Heater Booster
Parametric Special Module
Parametric Special Module Prep
Road Hazard Warning Lamp
Fire Extinguisher
74 MPH Top Speed Limitation
Additional Warm Water Heating
First Aid Kit
Upper Cargo Lashing Rails
Rear Wall Trim
Front Overhead Storage Bin
Rear Black Rubber Floor Covering
Waistline Cargo Lashing Rails
Half Laminated Wood Cargo Panels
Half Fiber Board Cargo Panels
Sliding Door Assist Handle
Right Rear Assist Handle
Left Rear Door Assist Handle
Panel Van Interior Lining Panels
Overhead Console w/Two Reading Lamps
Floor Cargo Lashing Rails
Cargo Partition
Hinged Lid for Center Stack
C-Pillar Cargo Partition
Rear Window Defroster
Rear Auxiliary Heater
Rear Floor Insulation
Instrument Cluster
Driver Base Seat Power Outlet
Locking Glove Box
12V Rear Auxiliary Power Outlet
Courtesy Lamps
Motion Sensor Cargo Compartment Lighting
Rear Convenience Lighting
Speed Control
Luxury Steering Wheel
Rear Seat Heat Ducts
Cargo Partition w/Sliding Window
Cargo Partition w/Window
Cargo Partition w/Sliding Door
Cargo Partition Provisions
Sunscreen Glass
Insulating with Band Filter Windshield
Heated Windshield
Rear Door Windows
Fixed Window In Roof
Black Vinyl Bucket Seats
Luxury Bucket Driver Seat
Driver Seat Comfort Headrest
Passenger Seat Comfort Headrest
Luxury Bucket Passenger Seat
Heated Driver Seat
Heated Passenger Seat
Dual Passenger Seat
Driver Suspension Seat
Passenger Suspension Seat
Gray Cloth Bucket Seats
Rear Spring Damping
Rear Door Windows w/Wiper and Washer
Left Sliding Door w/out Glass
Power Heated Mirrors
Manual Parcel Service Black Mirrors
High Pressure Headlamp Washer
Bi-Xenon Headlamps
Fog Lamps
Dark Gray Rear Bumper w/Step Pads
Front License Plate Bracket Delete
Black Blue Paint
Black Gray Paint
Stone Gray Paint
Silver Gray Paint
Carbon Black Metallic Paint
Broom Yellow Paint
Coca Cola Red Paint
Graphite Gray Paint
Jasper Blue Metallic Paint
Brilliant Blue Paint
Brilliant Silver Metallic Paint
Graphite Metallic Paint
Flame Red Paint
Amber Red Metallic Paint
Jet Black Paint
Side Entrance Protection Strip
16" x 6.5" Aluminum Wheels
Jet Black Painted Wheels
Arctic White Painted Wheels
AM/FM/CD Stereo w/Telephone Connection
6-Disc CD Changer
100 Amp Auxiliary Battery
Preset Idle Control
Option Package 22A
Option Package 22B
Option Package 24A
Option Package 24B
Premium Sound Group 1
Accessory Group
Light Group
Cold Climate Comfort Group 1
Crew Van Group
Comfort Seating Group
Trailer Tow Group
Security Group
Window Group 1
Window Group 2
Window Group 3
Window Group 4
Auxiliary Front Heating Group
Rear Back-Up Camera Group
Contractor Group
Cargo Group 1
Cargo Group 2
Cooling Group
Base Insulation Group
222222222222222222222222222222222222222222222222
2006 3500 hi roof 140
from sherman dodge in skokie il
Block Configuration: I
Cylinder Quantity: 5
Aspiration: Turbo Charged
Cam Type: double overhead cam (DOHC)
Valve Quantity: 20
Horsepower: 154
Horsepower At (RPM): 3800
Torque: 243
Fuel Capacity (gallons): 26.00
Capacity/Dimensions
Length (inches): 225.00
Height (inches): 103.00
WheelBase (inches): 140.00
Ground Clearance: 6.00
Curb Weight (pounds): 5221
Cargo Capacity Max (cubic feet): 367
Luggage Capacity (cubic feet): 367.00
Payload Max (pounds): 4769.00
Maximum Seating: 2
Towing Capacity Max (pounds): 5000.00
Turning Circle (feet): 42.00
3333333333333333333333333333333333333333333333333333333333333333
2006 hi roof 3500 158
Valve Quantity: 20
Horsepower: 154
Torque: 243
Capacity/Dimensions
Length (inches): 263.00
WheelBase (inches): 158.00
Ground Clearance: 8.00
Curb Weight (pounds): 5242
Cargo Capacity Max (cubic feet): 473
Luggage Capacity (cubic feet): 473.00
Payload Max (pounds): 3308.00
Maximum Seating: 2
Turning Circle (feet): 47.00
nothing available in the other categories on this one.
4444444444444444444444444444444444444444444444444444444444444444444
2007 3500 170 not specified as high roof
Engine Type: diesel
Valve Quantity: 24
Horsepower: 154
Torque: 280
Axle Ratio: 4.1
Capacity/Dimensions
Curb Weight (pounds): 5978
Payload Max (pounds): 5052
Maximum Seating: 2
Towing Capacity Max (pounds): 7500
Mechanical
[Tires] Prefix: LT
[Tires] Profile: 85
[Tires] Width: 215
[Wheels] Width: 5.5
Safety
Exterior
[Roof] Roof rack
Interior
Security Alarm
Rear BackUp Alarm
Front Axle Reinforced
3.92 Axle Ratio
220 Amp Alternator
Wood Floor Delete
Additional Keys
Radio Prep
Heater Booster
Fire Extinguisher
First Aid Kit
Gross Vehicle Weight Rating of 11030 lbs.
Rear Wall Trim
Shelf Above Roof Trim
Instrument Cluster
Locking Glove Box
Courtesy Lamps
Speed Control
Sunscreen Glass
Heated Windshield
Rear Door Windows
Heated Driver Seat
Dual Passenger Seat
Front Heavy Duty Stabilizer Bar
Rear Stabilizer Bar
Reduced Overall Height Suspension
Bi-Xenon Headlamps
Fog Lamps
Mega Roof Painted
Mega Roof White
Black Blue Paint
Black Gray Paint
Stone Gray Paint
Silver Gray Paint
Broom Yellow Paint
Coca Cola Red Paint
Graphite Gray Paint
Flame Red Paint
Jet Black Paint
6-Disc CD Changer
Preset Idle Control
Option Package 22A
Option Package 22B
Accessory Group
Light Group
Crew Van Group
Trailer Tow Group
Security Group
Window Group 1
Window Group 2
Window Group 3
Window Group 4
Contractor Group
Cargo Group 1
Cargo Group 2
Cooling Group
Cargo Partition
Mechanical
[Tires] Prefix: LT
[Tires] Profile: 85
[Tires] Width: 215
[Wheels] Width: 5.5
Safety
Exterior
[Roof] Roof rack
Interior
Mechanical
Engine Type: diesel
Valve Quantity: 24
Horsepower: 154
Torque: 280
Axle Ratio: 4.1
Capacity/Dimensions
Maximum Seating: 2
Safety
ken, rlent and geo hope this is enough info. i'm slackin' i know.
Jack Berry
