The CSA system or methodology will continue to evolve as more flaws or issues with it's approach to assigning carrier safety fitness are discovered. FMCSA states the system should not be used by the public to determine safety fitness - but it is.
All carriers and drivers really need to research and understand CSA and how it actually works. It is most important that we all embrace and abide by ALL of the FMCSA regulations while learning to understand the CSA system. The violations you receive in roadside inspections, and your moving violations and crashes not only adversely affect the carrier you operate for, but also yourself. Those violations and crashes affect the carrier's CSA basics and the driver's PSP reports. Carriers are becoming reluctant to hire drivers with substantial violations on the PSP report. Drivers will find it more difficult to move from carrier to carrier.
Load One is a very safe and reputable company. Panther is a very safe and reputable company. Most carriers are feeling the effects of the CSA program and some of it's unreliable data. If you reasearch CSA you would discover a "weighted" system. Under this system new or recent violations count three (3) times as much as the violations that are old enough to be removed from the carriers' record. Understand that you cannot continue to receive violations in the same frequency as you have in the past - the carrier's basic scores will tumble into alert status very quickly, and once in that status, it is very difficult and takes much time to return from alert status. Alert status and receiving violations on roadside inspections or moving violations causes a carriers ISS (Inspection Selection System) score to rise. The ISS score is what roadside inspectors use to determine wheter to inspect a truck or not. The higher the ISS score, the higher chance your truck will be inspected. The more inpections a carrier has, the higher probability for more violations to be discovered and the higher probability that the carrier's CSA basics score will continue to rise. It is tough to break this cycle. In addition, the increased inspections can cause drivers to accumulate more violations on their own PSP reports. Hopefully now you see why it is so important that we all (carriers and drivers) somehow acquire a warm, fuzzy, loving feeling for the regulations and abide by all of the regulations.
Looking at the old Safer Sys system we all can see that Load One and Panther are well under the National averages for Out of Service violations in all categories. A new system is being implemented (CSA) which is far from perfect, but we must change and adapt to it.
If you are leased or drive for Load One and John Elliot please do your best to get "clean" roadside inspections and avoid moving violations. That is the best thing you can do to help your company at this time. Take time to research CSA - it will make you a better driver. We all want to be better at our jobs.
Thank all of you drivers for the jobs you do.
