Lets Remember September Locatoons & More
Middle of the night dispatch. 2AM pick in Tulsa and direct to Northwest New Mexico, DH back to Albuquerque, all covered by good rate. Then it's a krap shoot, give Albuquerque a chance or bite the bullet and drop down to EP?
My excitement when offered a load to NM ...
Never had a water in fuel problem
Good to know. Seems like the water in fuel sensor caused more problems then it fixed :rolleyes:
And I failed in my main goal not to screw up this project :dash2:
I was so freaking close to completion. Even removed parts I said i wasn't going to do to gain better access to the low pressure pump. Even though the connection fit, it didn't look like it was all the way in. So I started to tap it further in. Apparently, I tapped one to many times, and the plastic fitting broke off :ohsnapcouch:
So, ordered another fuel line. I knew i should of ran my errands before starting this. But what could go wrong :rolleyes:
NorthernBill
Waiting to load, Buford, GA to Erie, PA.
Had a real nice bike ride to Cherokee, NC, then return to Forsyth, GA. Casino gave up $70 from gaming, we spent $200 on room and food, good times.
Bike started running like it should after the first 100 miles, gas was a year old.
Back to the grind, feeling good about getting out of GA. was 10 XPO vans near Atlanta this morning.
billg27
Albuquerque is a fun place for a day. If nothing by 19:00 personally I'd make the drive to El Paso. Murray has very good luck from EP!
Reactions: NorthernBill
Last time we spent a day in Albuquerque, nothing happened except sightseeing, next day we went to EP. We are heading 150 miles NW of Albuquerque to deliver at 16:30MST. By the time we get back to Albuquerque we will head to J, probably hang Thursday and if nothing go to EP tomorrow night and hope for Friday Magic from the Magician
Sounds like a plan:)
Reactions: xmudman
xmudman
Grants?
Tennesseahawk
If'n you like smooth jazz and r&b, check out 103.7 in Albuquerque. You don't find many stations like that around the country anymore.
