All you have to do is take a close look at the rear doors of a trailer that has Airtabs and you'll know immediately that drag is dramatically reduced with those things. The rear doors stay far cleaner than on trailers without them.
Follow behind one with Airtabs on a wet road and you'll notice a marked decrease in road spray on your windshield, as well. With Airtabs, not only does the spray stay down and off the windshields of those behind you, it stays down and out of the view of your mirrors, enabling you to see better back there.
Airtabs are basic aerodynamics, all about reducing resistance. They reduce the lower atmospheric pressure (drag) behind a moving object. A moving vehicle creates a pocket of lower air pressure, and the surrounding higher pressures will want to move into there to equalize the pressures. The vehicle is inside the higher pressure "zone" and therefor gets sucked back into the lower pressure pocket, so the lower pressure zone wants to "drag" the vehicle back into that low pressure. Airtabs disrupt the airflow that causes the low pressure, eliminating a large chunk of the drag.
Airtabs and properly inflated tires (nitrogen) are two of the most cost effective things you can do to reduce resistance, which reduces the load on the engine, which results in lower fuel consumption.
