Hi Greasytshirt.
would love your input regarding my new to me second hand service truck. Previously had 2001, 6speed Hino with s05c, constantly overloaded at 5800kg, brilliantly reliably little bus, no race car and liked a drink but hats off for reliabilty!! Moved it on with near 400000km only servicing & one set of front brake pads and radiator top tank. Still not using oil or any oil leaks.
Bought 2004 hino so5ct 6speed, with 150000k one owner, in the first 5000km. i have had to dip in to my pocket for water pump, raditor, lift pump & set of springs & shackles. I am concerend about an engine noise (tap tap / knock knock). I have done oil analisys after 1000km and now again after 5000km since oil change = clean & good. The noise is mostly there but seems to change in loudness, some times more pronounced when under full load and hot (summer just started here).
Also noted when engine is cold and intially driving slowly at low rpm along driveway the engine ecu seems to siginficantly change / alter the engine note depending more so on throttle position ( does not seem to be so much load related). There is also a certain iregularity a bit like hunting but not quit, whilst this change of note is going on. If engine is cold / slightly warm and you run it at say 800 - 1000 rpm no load it some times runs in a sort of irrregular (not missfiring) pattern. I presume that the ecu is somehow doing this. I have had a couple of other mechanics have a listen to this but no clues. Another thing that i find a bit unusual is that, we have a slow steep hill climb which i take every morning, the previous truck with s05c would climb very easily at 800-1000rpm in first gear and respond to throttle increase.
This truck struggles unless i am in boost range say 1200 - 1400 rpm, if under this rpm then it will drop back just above idle and just manage to not stall. I am presuming that is due to lower compression in turbo engine and therefore less torque at low rpm??
My Weight 6500kg
Ps my first go at this forum and not a forum man usually.
Thanks re ralf
My Weight 6500kg
Thanks re ralf
