Hello Greasytshirt,
Thanks in advance for your time and hope all your problems are entertaining enough to keep you from getting bored.
Ha, it's never boring. I have a story from today. A lease truck rolls up, it's a big ol' moving van. Same setup as yours, '09, DPF only, no SCR system. The complaint is low power and a check engine light. It has an inactive P2002 code, and it's out of warranty. The DPF indicator is at ten bars. Whatever you do, don't let it hit ten bars. Not long after that, it reaches a point where the truck can't clean the soot via regen, it'll have to be cooked out or the whole thing replaced.
So yeah, P2002, no other codes. On cold start, there was lots of clatter. I know that sound. Either the injectors are going south, or it has an original, unmodified Intake Throttle Valve on it. I hooked the computer up, ran a SCV test, and watched the injection quantity jump all over the place. Pulled the black tube off of the intercooler, and there it is, an original, unmodified ITV. I took it off and performed the needed modification. There was oil in the intercooler outlet, so I checked the oil level. Massively overfilled. I drained about six quarts. The air filter was filthy, replaced it. Checked the hoses at the DPF differential pressure sensor, and one was clogged. It tok a while to get all the junk out of it.
Any one of these things could have caused a P2002, if bad enough.
Since this thing is out of warranty, I'm not going to condemn the DPF without trying to regen it first. I initiated a forced regen and watched the DPF temps. Everything was looking ok at first, but the outlet temp was soon far behind the inlet temp, indicating that it's not heating evenly. Usually they're only about 100-200 degrees apart, give or take, then the inlet and outlet match each other for several minutes, then it's done. In this case, there's a 500 degree difference between the inlet and outlet. A few minutes later, the outlet temp starts to rise. And boy, she's coming up fast. Alarm bells went off in my head when it hit 1100. 1300 degrees came less than five seconds later. At this point, I clicked 'End Inspection' and I'm going for the key when the exhaust brake opened, and with a loud "BOOM!" it shot a fireball out of the tailpipe. Never seen that before.
I'll have to look at the system protection data and see how many times it's hit an overheat condition. Dozens, I'll bet. The exhaust brake was set way too high when it arrived, so I adjusted it down before even attempting it. Then I'll drop the DPF and see if it's melted down. This one is a candidate for going in the DPF oven, since soot has not permeated the filter (which was a huge surprise).
