Ray's partner Bryan did the install. I never got a manual, just the diagnostic sheet for the controller.If you did your own install and saw the instructions. There is a solid grey wire from the wall mounted thermostat in the wire harness. If you disconnect that wire the heater defaults to using its internal thermostat located at the air intake of the Espar. Mine didn't work right either. I cut that wire and it now holds temp very well. I set mine at 76 and it keeps the van warm under all conditions. It's an easy remedy.
Yeah, the colder it gets the worse those State Troopers are.and having to be rescued from a State Trooper in -27f temperatures
You sleep ALL NIGHT with it on? How many hrs straight thru?Van is insulated. Buddy heater with 20lb tank. I keep it on low and sleep on an air mattress with 4 inch foam mattress with a sleeping bag. The coldest outside so far has been 18 degrees and still comfy warm inside
I just pull the wife a little closerThere should always be an "other" category. I, for one, would choose 'other'.
Note to self....... Don't do it, Turtle is watching.....I light farts on fire.
