Broompilot
Here is my EXCUSE, so much for PTI there is on most Volvos a little found stick that comes out of the engine (Yellow) I believe. It even has a marks on the end of that stick where the oil level should be.
This should be checked daily but at least daily for a week or so after an oil change. Also by putting ones hand on the front bumper and bending over one can see amazing things under there.
Coolant or No Coolant no coolant is a good sign, Oil or No Oil puddles none is another good sign, some drips are OK but pudddles are real bad, Transmission Fluid or other Types of Transmission fluids or Grease, same is true at the rear of the Truck.
It is what you posted, the driver Never Realized 8-days there had to be a clue along the way.
Just another example of drivers in ones truck and what the costs of a simple lazy oversight might cost an owner.
Every Repair on my Expedite Truck that I accomplished was due to finding puddles of one type or another. Most were from loose fittings on coolant lines. Had I not of found them the results would have been costly on the side of the ROAD. A MECHANIC I am not, but I do know when trouble is brewing and what needs to be done, FIX IT BEFORE it gets real expensive.
