The HAZMAT label on the container means it's HAZMAT? Really? You really need to let the DOT know that, because they think otherwise. Labels are required on the outside of the package regardless of the quantity shipped, as long as the material shipped can be shipped in a quantity that would classify it as HAZMAT. The fact that some package has a HAZMAT labels on it does not make the load a HAZMAT load. Only the shipped quantity is what determines whether or not it is HAZMAT.Ok, let's see if I can explain this so you can understand.....
If I have a 100 lb container of corrosive, the container has to have HAZMAT LABELS on the container(which means it is hazmat),
If you haul HAZMAT, you must have a CDL and a HAZMAT endorsement on that CDL. Yet, someone without a CDL can haul a 100 pound package of corrosive. You have to ask yourself, why is that? The answer should be obvious.
The FMCSA regulations for paperwork specifically state that non-HAZMAT material cannot be marked as HAZMAT unless the quantity shipped classifies it as such. Have you not read the regulations?the paperwork has to be marked as HAZMAT,
Correct, as 100 pounds of Class 8 Corrosive is not HAZMAT. If you are hauling HAZMAT, then you are required to have placards on the truck. If you aren't required to have placards on the truck, then you aren't hauling HAZMAT.but you don't have to have HAZMAT PLACARDS on the truck.
If it's a danger to the public (or the environment), then it's HAZMAT. If it's not a danger to the public (or the environment) then it's not hazardous materials. If it is, in fact, a danger to the public, then you have to alert the public to the potential danger. That's what placards are for.
That all depends on if it's a reportable quantity. A truck battery is corrosive, too, but if it leaks you don't have to call a HAZMAT team out to clean it up. Sulphuric Acid, a Class 8 Corrosive, has a RQ of 1000, meaning a spill of anything more than 1000 pounds would require reporting it, and a HAZMAT clean-up team. You also, coincidentally, don't have to placard a load of Sulphuric Acid of 1000 pounds or less. Funny how that works.It is still a corrosive. If this container leaks, you have to have a HAZMAT team come out to clean up the leak and overpack the container.
No, I wouldn't say that, but that's not the criteria for what makes something hazardous material. If it were, then a bucket of rusty nails or old razor blades would be designated as HAZMAT. It's not about being dangerous to just anyone, or to just a few anyones, it's about being a potential dangerous threat, and unreasonably so, to the unwitting public at large. A 100 pound package of corrosive, unless it's in a concentration that designates it as being HAZMAT, doesn't present an unreasonable threat to the public at large. 1001 pounds would, tho.Because it's under 1001 lbs, you wouldn't say it's not a danger to anyone who would stick their hand in it, would you?
If you read that carefully a few times, it will eventually dawn on you that unless the material has been designated as hazardous, then it's not hazardous material. And it will also dawn that unless it is required to be placarded, it's equally not hazardous material.Hazardous materials means any material that has been designated as hazardous under 49 U.S.C. 5103 and is required to be placarded under subpart F of 49 CFR part 172 or any quantity of a material listed as a select agent or toxin in 42 CFR part 73.
A 5-gallon bucket of (non-water based) paint has to have a HAZMAT label on it, but a single 5-gallon bucket of paint is not a danger to the public or to the environment if it's spilled or if some goober sticks his hand in there, so it's not HAZMAT. On the other hand, forty 5-gallon buckets of paint, if spilled, would most definitely be a danger to the environment, and that's why that much paint all at once is HAZMAT, and why just 5 gallons isn't. And not all paints (like water-based paints) are even subject to being hazardous in quantities, just like not all corrosives are. It depends on the material (mostly its concentration) and the quantity.
Class 8 Corrosives are only considered HAZMAT at 1001 pounds or more, and less than 1001 pounds are not classified as HAZMAT. This isn't something I've figured out on my own, or heard from another trucker, or on the CB, or read on a Web forum. It's information I got directly from the FMCSA and the Code of Federal Regulations.
Yes, I do.Do you have a hazmat endorsement??
Then I'm a little surprised, but then again I'm really not. When you haul HAZMAT in a cargo van you really have to know the particulars of this stuff, for a myriad of reasons, not the least of which is that scale master likes to pick us off like sitting ducks on a fence post. But in a straight truck or a big truck, some of the particulars don't matter, you just do everything the same and it doesn't matter.I've been hauling hazmat for 18 years.....
But in a van, you have to really know what the difference is between Table 1 and Table 2, their reportable quantities, as well as knowing which types of HAZMAT you cannot even put into a cargo van regardless of the quantity. Class 6 6.1 (a&b) Poisons - Inhalation Hazards, for example, can go into a cargo van, but only if it is PG I that has been packed for PG III. If it's PG I and packed as PG I, then it cannot go into a cargo van, even one with a sealed bulkhead. This is stuff you don't need to be concerned with in a straight truck or in a big truck, but it's critical in a van, not only to keep from breaking the law, but it could mean your life.
Most people (and carriers) simply go with anything from Table 1 doesn't go on a van, and anything from Table 2 can. And some go as far as anything from Table 2, but not if it's 1001 pounds or more, because then the driver would need a CDL and the endorsement, and a lot of van drivers don't have either.
But you don't need to trust me on any of this. Go read the regulations for yourself. It's all in there. This is your job, so you might as well.
There's a lot of stuff I don't know (believe it or not), but one thing I do know is, some goober slapping a HAZMAT label on a package does not determine if the shipped freight is HAZMAT.
