We have had both a StreetPilot 2720 (wife) and a StreetPilot 7200 (myself) for about 2 years. I've used both.
While I'd generally agree with most of Ken's comments, there are a couple of places I'd differ:
Have never had any problem with the resolution on my 7200 - the resolution is higher than, or similar to, the other units - but since it is spread over a larger area it appears somewhat more coarse. Even given that I'd still prefer the larger screen over the smaller size of the 2720 - I just find it easier to make out what's going on .... and I have mine windshield-mounted immediately to the right of the instrument cluster, above the dash.
The only time I've noticed a somewhat lower screen brightness is after leaving the unit on overnight while I'm sleeping - I'd guess that turning the unit off and then back on would resolve it - but I've never tried that. Probably a bug in the code for the switch from "Night" mode to "Daylight" mode.
The 7200 could stand to have the newer SIRF II chipset in it - it is a little slow to acquire it's satellites when you first turn it on (takes a couple of minutes) - and it will lose the satellites going thru a long tunnel (Allegenhy in PA for example) I've never ran NYC but I'm sure that it would lose it there (I'm only using the built-in antenna - reception might be better with an external.) I don't do alot of big city downtowns - mostly stay on the interstates .... just passing thru .... and have never had a problem in those circumstances. In my opinion you would have to be right in the very core of the high rise area in a downtown to have it be a problem.
I have not had any real problem with it in the mountains either (just PA, VA, WVA, NC, KY, TN so far) - other than it on a very few occassions losing signal momentarily - it will recover in less than 30 seconds and almost always in less than 15. Keep in mind - this is when I'm flying down the interstate - if I had to navigate the "hollers" in WVA it might be different. Same deal with dense overhead foliage. If you were doing alot of big city downtowns the dead reckoning feature would definitely be handy to have.
I don't have the traffic subscription so I can't comment on that but I could see where it could be very handy. I see the GTM12 antenna is available for around $160 from Garmin (might be cheaper online somewhere)
The 7200 (and 7500) both have TTS (Text to Speech) - this allows them to "speak" the actual road names for turns - so instead of just getting "Turn right" you get "Turn right on Main Street" instead - this can be very handy in the city where you might have several apparent choices at an intersection - it saves you from having to look at the screen to try and figure out what road you actually need to take. Not sure which of the newer units have this.
"First and foremost, a laptop or an Atlas, even under the best of circumstances, are both cumbersome and unsafe to use while driving. This is particularly true when being used in "complicated" areas when you need to refer to the map the most, like in congested areas where there will be several quick routing turns one right after the other. That's precisely the time when your attention must be more focused on the road and on others around you, than on a map."
After co-driving a 600 mile run from Ohio to Iowa in another party's vehicle where he brought his laptop GPS system along, I'd fully concur with the above statement.
I can't imagine trying to use a laptop on an ongoing basis, particularly in any kind of traffic situation. It's just plain unsafe - simply because you are never going to be able to mount it where it is in your line of sight. The fact that they aren't touchscreen only makes it even worse.
Long story short: a standalone, dedicated automotive GPS is designed with a specific purpose - to be used for navigation in a vehicle - a laptop isn't.
