westmicher
We use a simple curtain on a spring loaded shower rod to reduce the cooled space to about 1/2 of the van... which makes it very cool inside.
Paul Harvey was a very good man...Ah, the Paul Harvey side of the story.
So for the cost of a curtain & rod you can save hundreds on an AC unit and hundreds more on a smaller KW generator plus a whole lot less fuel burn, less weight and less aerodynamic drag (no roof top)...all this because of a $10. curtain rod and curtains? Gotta like Paul Harvey!We use a simple curtain on a spring loaded shower rod to reduce the cooled space to about 1/2 of the van... which makes it very cool inside.
Look at westmicher pictures of his A/C install. He installs a small door in the side of the van, which stays closed until you deploy the a/c. He's got some good pictures.So for the cost of a curtain & rod you can save hundreds on an AC unit and hundreds more on a smaller KW generator plus a whole lot less fuel burn, less weight and less aerodynamic drag (no roof top)...all this because of a $10. curtain rod and curtains? Gotta like Paul Harvey!
Thanks, I'll check it out. I think its great when someone comes up with good alternatives to the status quo. I will be installing my hard start capacitor this weekend for my 14k btu unit. The little eu2000i is still doing the job without it but there is a notable momentary struggle. In the mean time, I installed an hour meter in the generator to better keep tabs on maintenance intervals. I haven't trimmed the ty wraps yet because I am testing different locations. I do think this will be the final location because no screws or modifications on the unit will be needed and I have to open the cover to check oil level anyways.Look at westmicher pictures of his A/C install. He installs a small door in the side of the van, which stays closed until you deploy the a/c. He's got some good pictures.
Ditto!I need to step in one of your vans on a hot humid day. When we were talking it sounds like our insulation is similar. I just can't wrap my head around a 5000 cooling an entire van on a 90 degree day with real high humidity. I'd like to check it out.
Good day!Ah, the Paul Harvey side of the story.
