Responses to various comments:
1. The distinction between WG and surface is not relevant here. This is a comparison of flat rate to percentage, regardless of the division within FedEx and regardless of carrier. Hypothetical Truck A runs on a flat rate. Hypothetical Truck B runs on a percentage of the load. There is nothing more to it than that.
2. Regarding the rates shown, Truck A approximates the flat rate pay stated by FDCC contractors here in the Open Forum. Truck B's $1.80 per mile is a number I made up, but I know of many straight trucks making that money or better with various carriers.
$1.80 a mile seemed reasonable to me for this discussion. If it does not seem reasonable to you, simply substitute a number that does. Below is the same table with a third column added entitled "Your Truck." It is blank so you can fill in whatever pay per mile you wish.
3. Regarding "way too many variables," I agree. I said as much in the original post when I described this table as an over-simplified item. However, with the third column added, ALL variables can be fully accounted for on a case by case basis. Simply fill in the numbers for your truck, accounting for all variables.
4. Regarding deadhead paid in various amounts on various loads for part or all of the deadhead miles; those are variables. Work your deadhead pay into the table in whatever way makes sense to you. You might treat all deadhead miles as unpaid and add your deadhead money to your paid miles. That might bump your $1.80 per mile to $1.83. It is not precise but it will work in this over-simplified table, enabling you to account for deadhead money. You could treat revenue for accessorials the same way if it is not already included in the $1.80.
5. Regarding Panther's currently advertised $1.49 per mile (or any rate offered by any carrier), you can change various numbers in the Truck B column (pay per mile, number of paid miles, number of deadhead miles, number of personal miles) to make Truck B's profits equal Truck A's. To make the profits of the two trucks equal by changing only the pay per mile, change Truck B's pay per mile to $1.664.
6. I put a copy of the live spreadsheet up on the web for anyone who wishes to download a copy to experiment with. Don't worry about screwing it up. If you screw it up, simply delete your file and download a fresh copy.
Click here to view and download the spreadsheet.
7. The $1.00 per mile cost for each truck is a general figure. Some trucks cost more to operate, some cost less. The number is the same for both trucks because it is assumed that both trucks and their drivers are identical in every respect, except in the number of miles driven and how they are paid.
8. I present this table not as an example of the numbers a given truck will have, and not to suggest that one compensation method is better than another. I present this table as a suggested approach to objectively compare one compensation method to another.
9. Finally, notice how jjoerger injects a subjective consideration that cannot be objectively built into a numerical table (miles and money can be objectively counted, "hates sitting" cannot). In his case, the choice of compensation method is not just about the money, it's about an emotional response to sitting too.
What works for us on flat rate may not work for others.
We hate to sit. Our goal is to run our miles to make the income we desire and spend our time sitting at home enjoying the other side of our lives.
