That has happened to me a couple of times also. All since the creation of the new system.Well, I 'had' a good run that would have salvaged this week.. as Caryn was dispatching to me, someone else was working on it at the same time apparently. Dale
Cluster of heavier snow showers lingering over the area will be capable of a quick burst of low visibility but with just light accumulation around a half inch between 1100 am and noon. After that... The activity will break up into scattered lighter snow showers during the early afternoon. Locations most affected by the snow showers will be from the i 94 corridor in washtenaw and wayne counties to the i 96/696 corridor in livingston and southern oakland counties. Motorists should be alert for sudden drops in visibility to 1/4 mile or less for short periods of time but over short distance.
the sun is out and it is coming down....
The first time, I was really happy to lose the load as it was one of those famous short, minimum rate loads. The second time, it was a Laredo load that got yanked away.
It seems to me that somebody had to be dispatching out of order...otherwise both dispatchers would be calling the same truck?
Not exactly. This was a case where the correct unit got the load. Our dispatch software is web based. So what happens at times and in a case like this is really an issue of "refresh". A dispatcher sees a load in the available load screen, they then look at their available unit screen and see the oldest unit. They try and assign the load to the truck and find out that it has already been assigned to an older unit. They didn't see the older unit because that screen had refreshed and taken the unit out of available status. But if the unit screen refreshed and the load screen didn't you can be "out of sync" for lack of a better term. Hopefully that makes sense to everyone?
im only 26,148 posts behind ovm....not bad
Like having 2 windows open at the same time...say EO on both windows...one will be different then the other because new info comes unto the page...you refresh only 1 window and it changes but the 2nd window does not...unless you hit the refresh button as well...
That makes sense. Is there any solution for the problem. Im guessing it is as frustrating for the dispatchers as it is for the driver.Not exactly. This was a case where the correct unit got the load. Our dispatch software is web based. So what happens at times and in a case like this is really an issue of "refresh". A dispatcher sees a load in the available load screen, they then look at their available unit screen and see the oldest unit. They try and assign the load to the truck and find out that it has already been assigned to an older unit. They didn't see the older unit because that screen had refreshed and taken the unit out of available status. But if the unit screen refreshed and the load screen didn't you can be "out of sync" for lack of a better term. Hopefully that makes sense to everyone?
