I don't know for sure, it's the first time I have used the phrase, at least in the last fifty years. But my Koolaid is Less filling.
koolaid...must be an American thingee....
Ok, I got a simple solution to this problem. Why don't all of our carriers create internal load boards and allow drivers to bid/pick which loads they want to do? If you bid on a home run and lose it, you can still bid on a lower mileage load and make money. There are some drivers who only want to do short jobs and be home on the weekend while some drivers like to do longer jobs. I think if you let the drivers bid on the freight as it is booked into the system, they will have no reason to complain about refusals and not getting the good loads.
Didn't Jim Jone's followers drink the poison in koolaid? blind faith?
Forced dispatch means that you rcompany offers you a load. You take it or you're fired.
The carrier can reserve only what is spelled out in the lease agreement that you agree to, nothing more, nothing less. If it's not in the contract, and you don't agree to it, they can't do it. Neither party can unilaterally force the other into something not mutually agreed upon.
Yes, no forced dispatch means I have the right of refusal, as you said, period, that's all it means. I have the right to accept or reject. But it doesn't give them the right to impose penalties against me that I do not agree to. If they can impose a penalty without mutual agreement, then they would be at liberty to impose any penalty they like, including fining you, say, $100 per refusal. A penalty is a penalty. There is no difference. Many carriers impose board position or availability penalties, because no one challenges them much, but there are certainly other penalties that people would challenge in a heartbeat.
As of January 2008, 21 states have added owner/operator statues to the books, most dealing with worker compensation, all dealing with taxes, and in the light of ever-decreasing state tax revenue, look for possible changes in classifications or carrier behaviors. Some states use the Blanket Approach in determining employee or independent contractor status, and includes such things as lease purchase programs where the driver leases the truck from the carrier. In most cases, they are, or will be, classified as employees. Other states use the Multi-Factor Approach, where several criteria must be met, the more common ones being that the owner/operator is responsible for the maintenance of the vehicle and has vehicle ownership or bears the burden for the vehicle's operation, they are paid for work performed and not by time expended, and the most common, that the owner/operator is what is known as free form control, meaning they freely determine the details and means of performing the service.
When applied solely to the performance while of a load, expediters generally are, in fact, free form and control, where the carrier has no control over ways and means of performing the required duties (load securement, routing, whatever).
But, once there are penalties for load refusal, the owner/operator is no longer a free form control entity in control of the details of performing a service. Negative incentives, like load refusal penalties, are designed to, and usually result in, carrier-controlled behavior of the contractor with respect to services performed. That gets into a very dark gray area, and many courts have ruled on individual cases in favor of the plaintiff.
The four common law tests are the categories of analysis are: (1) Right of Control Analysis, (2) Modified Right of Control Analysis, (3) Relative Nature of the Work Analysis, and (4) Restatement of Agency Analysis.
In the Right of Control Analysis, the factors that are most often referenced in the case law regarding whether owner-operators are to be classified as independent contractors or employees include: (1) forced dispatch, (2) equipment ownership, (3) length of route/opportunity to make detail decisions, (4) delivery time deadlines, (5) reporting to dispatch requirements, (6) protocol for hiring/firing other workers, (7) personal appearance standards, and (8) discipline protocol.
Some of the above, like the delivery time deadlines, are part of the load contract that is either accepted or rejected, and is not much of a factor in expediting. But it's the first one and the last one, forced dispatch and discipline protocols, when used in conjunction, that has resulted in (at least) 28 states (I can name them if you like) recently ruling that penalties for load refusals doesn't satisfy the requirements of independent contractor.
These were workers compensation cases, which doesn't seem to apply to us, but when a court rules in favor of the petitioner, thereby ruling them an employee, it gets the attention of the Risk Management folks at carriers, because all kinds of ramifications can follow.
Can a dispatcher ignore you for refusing a load? Absolutely, and they sometimes do. Dropping board positions and reduced availability for refusing loads has been, and continues to be largely an accepted practice. But when it's blatant and structured, that's where they can get into trouble, unless you accept it or agree to it. Leased Carriers are not obligated to find you loads, and you have no punitive recourse if they do not, but they are contractually obligated with the Duty of Trust and Confidence provision to provide fair opportunities for loads. So when a carrier puts you OOS or drops you to the bottom of the board, what happens with load opportunities while you are otherwise forceably unavailable for loads can come back to bite them. There's a reason you no longer lose your board position for a load refusal at Panther.
