Expedite With Tractor and Pup Trailer?
paullud
Larger driver pool to draw from
That is a huge benefit I forgot about plus I think ST drivers are more professional and more likely to take care of the equipment. Of course that statement is a generalization and opinion but is based on my experience. The fact that you are more likely to end up with a H/W team can mean less time at home which decreases DH and down time.
zorry
Fedex's Pup Program was cheap and easy to set up.
It's designed for solo's looking for regional work, home weekends.
Putting an experienced TT driver in a pup should attract a good quality of driver as many want that home weekends lifestyle.
Tennesseahawk
Now I know a pup is 28', generally. But when it comes down to it, a 28'er is not giving too much advantage over a 24' straight, other than weight. Now, what I call a pup is up to 40'. I don't generally compare them to straights, as the benefits are a given... or should be. I tend to compare them to traditional 53' trailers.
Arguments for a small to medium trailer vs a straight truck:
-Both allow you to turn around in a narrow area. Advantage - slightly straight.
-Both allow you to park in a smaller space. Advantage- slightly straight.
-Need a CDL-A for a pup vs a B for a straight. Advantage - straight.
-Restricted roads. Advantage - straight.
-Tolls. Advantage - straight.
-Fees. Advantage - straight.
-Insurance. Advantage - straight.
-Mileage. Advantage - slightly straight, depending on weight.
-Ability to drop your trailer while they're loading you over 6 hours. Advantage - pup.
-Repairs - slightly pup.
-Replacement components. Advantage - pup.
-Replacement vehicle availability. Advantage - pup.
-Sell-ability. Advantage - Advantage - pup.
-Transfer-ability into a new venture. Advantage - pup.
-Flexibility in loads. Advantage - pup.
-Rate. Advantage - pup.
-Profit. Advantage - pup.
-Having what the others don't. Advantage - pup.
Overall... I'll let you decide that one. It all depends on what you're after. But IMO, a T/T driver who wants to downsize, would probably be ok in a pup. What turned me off with the 53'ers is that they were 53', not that they were trailers.
Tennesseahawk
I would think a single axle tractor and pup has a maneuverability advantage.
I agree. Something bigger, say a 35' to 40', the straight has the advantage.
If all you're doing is making a cheap 28' D unit, then I'd say it all depends on what you're trying to do with them. You aren't going to get a huge advantage in load flexibility, but you can put one together easier than you can a straight. A $15k tractor and a $6k-9k pup, and you're solid for a few years. Then you can replace whatever is out of date as needed, rather than putting a new box on an old straight truck. Drop and hook, man!
zorry
Drop at a slow loading customer.
Drop in a secure hold while you go enjoy the week-end.
