Tonight might be 1rst night of supplemental heat for the winter season...Another load .... another pond![]()
another day .. another pond
That wouldn't work for a Sharp Prick like me ..
You definitely need the heat where you are going.Loaded .. Vermilion, SD to Roseau , Mn... Canadian border ...![]()
There is a Warm Breeze coming from NW South Dakota so that might HELP...You definitely need the heat where you are going.
There is a Warm Breeze coming from NW South Dakota so that might HELP...![]()
Perhaps a cowboy is warming up the air?
another day .. another pond![]()
They say it’s snowing in SanAntonio now...eagle Pass thru to HoustonPerhaps a cowboy is warming up the air?
At first glance, I thought you said "Perhaps a cowboy is warming up in there." I envisioned a cowboy using a lightsaber on the cow, like Han did the tauntaun. Probably take the margarita mix in with him, as that cow looks downright tropical.
about time....A tad chilly here in S.E. Michigan this morning. The lakes and ponds appear to slight crust on the surface.
Yahoooooo!..... That means ice isn't far behind. Can't wait to go ice fishing.
A balmy 14° with 6 to 8 " of previous snow cover here in Roseau ,Mn ... survived the night as i was to lazy to get out of van to turn on LP tank valve for big buddy heater ... no problem.. slept 8.5 hours ..about time....![]()
I am sooo glad I packed it in....the drive from Rapid to home was for awhile white knuckle....wind blown snow over highway and ice underneath...floating feeling on the over passes..I do NOT miss what you guys are enduring...A tad chilly here in S.E. Michigan this morning. The lakes and ponds appear to slight crust on the surface.
2 lost bid loads already .. so driving closer to Fargo ..
My drive here wasn't bad .. it warmed up the further north i went in th Dakota's ... 26° north of Fargo ... once headed into Mn. it cooled off plus snow cover ... not bad reallyI am sooo glad I packed it in....the drive from Rapid to home was for awhile white knuckle....wind blown snow over highway and ice underneath...floating feeling on the over passes..I do NOT miss what you guys are enduring...
