What water temps is your engine running? If too cool, my quess is the white smoke condition is a symptom of your truck running too cold and the air inlet heater can't keep up. The above blog states "The air inlet heater also reduces white smoke when the engine is cold." You may not be reaching a needed operating temp to make the Cat sing on tune. That being said, the only time I had excessive white smoke was right before the HUEI pump failed, but it was a steady smoke bomb for about 30 miles and eventually quit two miles from the Cat dealer I was headed to.
I ran into an expediter in CA with 1.3 million on his C9 (mine 943,000 mi.s) and neither engine have been cracked open or heads off, only peripheral components replaced as expected. I think he sd he'd been thru 6 HUEI pumps, I'm on my 3rd, 1st went at 453k, 2nd went at 581. I have found Rotella full Synthetic tends to clog the injector tips. Changed to Dello full Synth and no more injector tip problems since. The Delo must burn with less carbon buildup. The one thing we both had in common was keeping the oil clean. I've been using the OPS bypass and running oil analysis.
Good luck, hopefully won't be too large of an expense. Let us know.
