Distance between wheel wells is 52.7 inches on both the single and dual rear wheel versions.
So is the DRW version equipped with extended wheel wells like a dually pick up?
The new ones are lucky to get 19-21 MPG, whereas the pre 07's are getting around 22-25 mpg...
Moot, I have an e-mail into them to try and get the GM /ford chassis specs as well as the comolete box dimensions. I too thought maybe that both vans were the same one and prototypes, but if you look the dual wheel van has the chrome grille and dual headlamps and the single has the black duraplas grille and single headlamps...so they are 2 different vans.
..but that doesn't mean the single wheel van wasn't built on a dual wheel chassis for the purpose of getting one together..
and yea the dual wheel van does look like it is wider above the body line... but the responce from the rep that both vans have 52.7 in dimension between the wheelwells makes me think the wider body look is just the photo angle affect...
Piper, was the Allison transmission ever available in a van? I know GM had to castrate the original Duramax to get it to fit into a van because there was not enough room when it was mated to the Allison.
Hopefully, Cargomaxx or whoever builds these things tags them at 9900 GVW. As the body builder, they are the manufacturer of the finished vehicle and they get to decide what the tag on the door says regardless of what GM built it to originally.
Why not 9990?
I sent a p.m. to cargomaxx and am hoping for more info in the future. This could be a nice van for expediting.
I am having a brain fade, but i think the single wheel incomplete tag at either 9200 or 9600 gvw...but i can't remember...but as was said, "coach" builder adds the finish gvw tag and its up to them...here is hoping for at least 9900 on the sigle wheel.....
The thing about silly Canadians is why do they get all the fun by having Bibendum on their trucks?
