I believe the reference above to CMVs over 10000# is inaccurate. From the information I have been able to obtain, the following is the most current available, and can be found at the links listed. I have included the actual wording as well.
Commerical Vehicle Impoundment Program (CVIP) (posted December 24/08 and referencing the following links
Highway Traffic Act, R.S.O. 1990, c. H.8
Highway Traffic Act - R.R.O. 1990, Reg. 587
The Legislation reads:
Note: On a day to be named by proclamation of the Lieutenant Governor, Part VI is amended by the Statutes of Ontario, 2008, chapter 8, section 1 by adding the following section:
Speed-limiting systems
Required use by commercial motor vehicles
68.1 (1) No person shall drive, or permit the operation of, a commercial motor vehicle on a highway unless the vehicle is equipped with a speed-limiting system that is activated and functioning in accordance with the regulations. 2008, c. 8, s. 1.
Same
(2) Except as authorized by the regulations, no person shall,
(a) deactivate, or permit a person to deactivate, a commercial motor vehicle’s speed-limiting system; or
(b) modify, or permit a person to modify, a commercial motor vehicle’s speed-limiting system such that it ceases to function in accordance with the regulations. 2008, c. 8, s. 1.
Tampering device prohibited
(3) No person shall drive, or permit the operation of, a commercial motor vehicle on a highway if the vehicle is equipped with, has attached to it or carries,
(a) a prescribed device or prescribed equipment; or
(b) another device or equipment that is designed to disguise the fact that the vehicle is not equipped with a speed-limiting system that is activated and functioning in accordance with the regulations. 2008, c. 8, s. 1.
Verifying compliance
(4) A police officer or officer appointed for carrying out the provisions of this Act, in exercising his or her powers under section 82 or 216.1, may require that the driver or other person in charge of a commercial motor vehicle,
(a) provide the officer with access to the vehicle’s computer system in order to retrieve and read any information relevant to the activation and functioning of the vehicle’s speed-limiting system;
(b) surrender to the officer any device or equipment carried in the vehicle that operates as part of the vehicle’s speed-limiting system; and
(c) surrender to the officer any records that the driver is required by the regulations to carry with him or her while driving the vehicle. 2008, c. 8, s. 1.
Same
(5) A driver or other person in charge of a commercial motor vehicle shall comply with any requirement made under subsection (4) by a police officer or officer appointed for carrying out the provisions of this Act. 2008, c. 8, s. 1.
Seizure of tampering device
(6) If a police officer or officer appointed for carrying out the provisions of this Act finds a device or equipment prohibited by subsection (3) in the course of any inspection of a commercial motor vehicle, he or she may detach, if necessary, and seize any such device or equipment. 2008, c. 8, s. 1.
Sale of tampering devices prohibited
(7) No person shall sell, offer or advertise for sale a device or equipment prohibited by subsection (3). 2008, c. 8, s. 1.
Offence
(8) Every person who contravenes or fails to comply with subsection (1), (2), (3), (5) or (7), or a regulation made under this section, is guilty of an offence and on conviction is liable to a fine of not less than $250 and not more than $20,000. 2008, c. 8, s. 1.
Evidentiary presumption
(9) In any proceeding under this section and in the absence of evidence to the contrary, proof that a commercial motor vehicle was driven on a highway at a speed equal to or greater than the speed prescribed for the purpose of this subsection is proof that the vehicle was not equipped with a speed-limiting system that was activated and functioning as required by subsection (1). 2008, c. 8, s. 1.
Forfeiture of tampering device
(10) Where a person is convicted of an offence under subsection (3), any device or equipment seized under subsection (6) by means of which the offence was committed is forfeited to the Crown. 2008, c. 8, s. 1.
Regulations
(11) The Lieutenant Governor in Council may make regulations,
(a) defining “commercial motor vehicle” for the purposes of this section;
(b) prescribing standards for speed-limiting systems;
(c) governing the activation and functioning of speed-limiting systems, including prescribing and governing the speed at which speed-limiting systems must be set and prescribing different speed settings for different circumstances;
(d) prescribing devices and equipment for the purpose of clause (3) (a);
(e) governing methods to verify compliance with this section and the regulations, including prescribing devices and software to be used to retrieve and read information in computer systems;
(f) prescribing the speed for the purpose of subsection (9);
(g) requiring and governing the inspection and maintenance of speed-limiting systems;
(h) governing records to be kept and submitted in relation to the inspection, maintenance, activation and functioning of speed-limiting systems;
(i) governing records to be kept and carried by drivers in relation to the activation and functioning of speed-limiting systems;
(j) exempting any person or class of persons or any commercial motor vehicle or class of commercial motor vehicles from any requirement or provision of this section or of a regulation made under this section and prescribing conditions and circumstances for any such exemption. 2008, c. 8, s. 1.
Note: On January 1, 2009, the Regulation is amended by adding the following heading and sections:
Speed-Limiting Systems
12. For the purposes of section 68.1 of the Act,
“commercial motor vehicle” means a commercial motor vehicle as defined in subsection 1 (1) of the Act. O. Reg. 396/08, s. 1.
13. (1) A commercial motor vehicle is exempt from subsections 68.1 (1), (2), (3) and (6) of the Act if it is,
(a) a bus;
(b) a mobile crane;
(c) a motor home;
(d) a vehicle manufactured before 1995;
(e) a vehicle with a manufacturer’s gross vehicle weight rating under 11,794 kilograms; or (Writer's Note: 11794 Kg = 26001 Lb)
(f) an ambulance, a cardiac arrest emergency vehicle, or a fire apparatus. O. Reg. 396/08, s. 1.
(2) For the purposes of clauses 1 (d) and (e), the date that a commercial motor vehicle was manufactured and its manufacturer’s gross vehicle weight rating shall be deemed, in the absence of evidence to the contrary, to be,
(a) the date and weight on the commercial motor vehicle’s compliance label; or
(b) where a commercial motor vehicle does not have a compliance label affixed or the label is illegible, a document from the vehicle’s manufacturer that is carried by the driver and that references the vehicle’s vehicle identification number and indicates its year of manufacture and gross vehicle weight rating. O. Reg. 396/08, s. 1.
(3) A commercial motor vehicle is exempt from subsection 68.1 (1) of the Act if,
(a) it is not equipped with an electronic control module capable of being programmed to limit vehicle speed;
(b) it is engaged in providing relief in an emergency, being a situation or impending situation that constitutes a danger of major proportions to life, property or the environment, whether caused by forces of nature, an accident, an intentional act or otherwise; or
(c) it is operated by or on behalf of a municipality, road authority, public utility or of the government of Ontario or of Canada while responding to a situation or impending situation that constitutes an imminent danger, though not one of major proportions, to life, property or the environment, whether caused by forces of nature, an accident, an intentional act or otherwise. O. Reg. 396/08, s. 1.
(4) A driver of a commercial motor vehicle is exempt from subsection 68.1 (1) of the Act if the vehicle is leased for 30 days or less by an individual for the transportation of the goods kept for the individual’s personal use. O. Reg. 396/08, s. 1.
14. (1)
The speed-limiting system of a commercial motor vehicle shall be properly set at a maximum speed of 105 kilometres per hour. O. Reg. 396/08, s. 1. (Writer's Note: 105 kph = 65 mph)
(2) A speed-limiting system is properly set for the purposes of subsection (1) if it prevents a driver, by means of accelerator application, from accelerating to or maintaining a speed greater than permitted under subsection (1). O. Reg. 396/08, s. 1.
(3) The maximum speed under subsection (1) shall be set by means of the electronic control module that limits the feed of fuel to the engine. O. Reg. 396/08, s. 1.
(4) A commercial motor vehicle is exempt from subsection (3) if it is equipped with an equally effective system, not dependent on the electronic control module, that allows limitation of vehicle speed, remotely or not, but does not allow the driver to deactivate or modify the system in Ontario so that it does not comply with subsections (1) and (2). O. Reg. 396/08, s. 1.
15. (1) A speed-limiting system shall be in good working order. O. Reg. 396/08, s. 1.
(2) Without limiting the generality of subsection (1), all aspects of a commercial motor vehicle’s computer system or systems, computer programs, components, equipment and connections that are capable of playing a role in preventing a driver from increasing the speed of a commercial motor vehicle beyond a specified value shall be in good working order. O. Reg. 396/08, s. 1.
16. A commercial motor vehicle’s electronic control module shall contain information that accurately corresponds with any component or feature of the vehicle referred to in the module, including information regarding the tire rolling radius, axle gear ratio and transmission gear ratio. O. Reg. 396/08, s. 1.
17. The prescribed speed for the purposes of subsection 68.1 (9) of the Act is 115 kilometres per hour. O. Reg. 396/08, s. 1.
18. The following devices are prescribed for the purposes of clause 68.1 (3) (a) of the Act:
1. A device that causes inaccurate information to be transmitted to the electronic control module about a commercial motor vehicle’s actual speed.
2. A device that causes inaccurate information to be sent to the electronic control module about the revolutions per minute of the engine. O. Reg. 396/08, s. 1.
