bnd automotive tk-704hs scf/tk-7scf gasoline
tughillrunner
Tercel,
We run both gasoline and diesel trucks on the TK-7SCF series and have since 2000. No I don't make it. I just let people know what my experiences have been because IT WORKS. I know Brian @ BND Automotive (440-821-9040) through experience from other people and on my own ofcourse. In the Gasoline vans, we have seen around 12% increase in fuel mileage, they pull harder, don't have to lug up and down hills with all the weight in them (1500-2000 lbs) and in most cases, they don't even have to downshift out of overdrive for hills. The technicians have pulled injectors in the vehicles, and have found them to be squeaky clean, and none of the seals or fuel components are affected by this product at all. One test a technician did before we started to use the product was to soak neoprene and Buna-N seals in the product for 3 weeks to make sure that it didn't attack seals. We mic'd the seals after the test and found them to be just like we put them in so that made us feel better about proceeding. A scope of the engine internals found them to be like brand new continuously regardless of miles. We don't have a problem with any of the fuel distribution pumps, and our Aim's tests (EXHAUST PIPE MANDATORY TESTS) have shown that the Hydrocarbon, Carbon Monoxide emissions have dropped about 1/2. One of the vehicles they had to run on the machine for 5 minutes and try the test again. We asked why, and they said they were trying to find some carbon monoxide, because "every vehicle gives that off". This particular vehicle showed 0 in both tests, and they finally passed it while scratching their heads. Diesel has seen very simular results, except a gain of 14-16% in that area. Both products have an ignition improver that allow you to burn 14% more of your fuel per fuel charge so you get better faster starts even in cold weather, and in diesel, no smoke. I look at the cost this way. GEO has negotiated to get all truck owners a special discount (call Brian and mention Geo's discount) and with that discount it is more than economical even in gasoline.
Example: 35 gallon tank 14 mpg average. This makes it 490 miles cruising range. 12% means 1.68 miles per gallon more with the TK-7SCF. 1.68 x 35 = 58.8 or 59 miles more. 59 miles divided by 14 mpg = 4.21 gallons saved with the old mileage being 14 and the new mileage being 15.68. 4.21 x 1.79 (87 Octane) = 7.54 saved. Cost of the product is 3.67 per tank of 35 gallons. 7.54 - 3.67 = 3.87 saved. This is what you can put down in comparative numbers. However things we have also verified with continued use is virtually no cylinder and bore wear. Stems and guides have no wear. No injector cleans or replacements, and it has cut my emissions in half so we are environment friendly! So, if you drive 1000 miles per day and have 10 gasoline vans each going 100 miles per day each van would use 7.14 gallons in 100 miles or 71.4 gallons that day. Using TK-7SCF in Gasoline you would save 8.57 gallons or 15.34 (8.57 x 1.79) dollars in fuel per day x 350 days a year = 5369.11 - the cost of the product for the year of 2628.50 would still net you 2740.61. (By the way, the cost of the product would cost you 7.51 to treat that 71.4 gallons.) Any product that pays for itself and then proceeds to give me 2500.00+ per year savings on fuel and no breakdowns is great for a fleet owner as you know so YES, IT IS WELL WORTH IT. :) :) :) :)
geo
bnd automotive also makes customs blend oils, just changed oil in my genset
and couldn't believe how much less noise it makes and also diesel
fuel is treated with the same fuel and that helps to make it
quieter too
also will be changing the oil in c10 and have ordered special blend to add to oil which give extra 5,000 before 10,000 and be able to go
15,000, cat dealeer where i do maintance said i could go 20,000
with the way i'm doing it now, but felt that was pushing it
a friend of mind is one that told me about bnd automotive product's
and you should try them, as he was having great return for money he spent
and mike l, drives for fedexcc has a er unit and lives in washington
state, has 887,000 miles on his t2000 and using different products
from bnd automotive
also weave my c unit has a c10 in it and getting 9.5 before using
tk-704hs, have 2 75 gal tanks, not pulling the weight of a trailer
do not idle my engine very much as i'm paying for fuel
now getting 11 mpg, will have engine computer read and will see how much better it's going
as 2006 is around the corner
teacel
Today I’m on my third tank of gas using the magic! Half way threw the first tank; I wanted to give Brian a dirt nap (stole this saying from Weave). My van started to act all crazy. It was pinging and choking. Spitting, sputtering and smoking like a house on fire. By the end of the first tank the van seamed to be back to normal. Second fill up using the magic, the van seamed to run fine. I called Brian and talked about it. The reason for the hissy fit was because the vans internal organs are cleaning up. Brian told me that I would start to notice the difference by the fifth tank. The testing goes on!!! Will keep all interested posted. [font color="maroon" size="2" face="face"]To be continued!!![/font]
[font color="gold" size="3" face="face"]FYI:[/font]
The question I ask tughillrunner regarding TTI. the company that makes this product and the involvement with Iraq was about a foreigner trying to infiltrate the company and get their hands on the Governments supply of 701 (TK-7). For those of you that don’t know what TK-7 is or how it came about; TTI invented and manufactured this for the US Government to use in their vehicles and Rockets.
Weave
Does this product have an SAE grade or an API service number? If manufactured for the military, it will. Is it a lubricant, fuel, or detergent, and if so, what are the grades? The numbers should give it away.
-Weave-
OK, I've been a bit obnoxious regarding this stuff. As it is YOUR truck you may add whatever you feel you want to your fuel, be it pee, nitromethane, Zippo fluid, etc. Note I have not stated in any of my posts that the product doesn't work. But I belive I am on the right line that the product is a fuel detergent, and there have been many of these products on the market for years.
-Weave-
