While running for a fleet owner, pretend you own the truck. Keep track of all fuel and maintenance costs. This will give you some realistic numbers to crunch when thinking about buying your own truck.
I'm assuming this is probably true with many carriers.. but, I know in my case, the Qualcomm gives every variable available for me to do the math as we accept the loads.
All the rates for deadhead, fuel surcharge, loaded miles, empty moves, load bonuses, special considerations, it's all there. Maintenance receipts go in a folder in the truck to be reported quarterly.
I can plug all of the numbers into side by side columns and make a very accurate comparison of each common payroll split option.
These are actual figures from actual loads, not guesses of best and worst case scenarios with generalized information.
The only remaining mystery is the $value of the truck payment. ($600/wk?) and the monthly fee the truck owner pays to the company for their important part. (150/wk?). Transfer those accordingly.
A. 40/60 - owner pays fuel
B. 60/40 - team pays fuel
C. Be 100% responsible for everything as an owner op
D. Solo vs. Team?
(As a team, this one is a rough guess for me.)
It only takes a few minutes to plug the numbers in for every load.
The results at the bottom of each column tell the tale.
There is a lot of opportunity in this industry for business minded people to do exceptionally well.
In the mystical world of expedited, nobody is in a better position to succeed than a dedicated and established team.
