Start at the pointed end and slowly and gently pry upwards. Don't use a metal spatula or anything like that. Use your hands, or a plastic spatula - anything that won't scratch the paint. Some of the tape may stay on the vehicle. If so, WD-40, Gunk or any degreaser or adhesive remover will get it off. Be careful not to get any degreasing agents on any adjacent air tabs that you don't want removed.Anyone know how to take the Air Tabs off relatively easy? I know they will not be able to be reused and I will need to buy more to make up for my mistake.
Drive really really fast ???
(I know,I'm useless...)
I did some searching for double sided tapes for those that are interested and came across this tape for the tabs. It is expensive though - @$27 per roll .5" x 10 yds.
"3M 06394 Automotive Attachment Tape is a .090-inch (90 mil) thick medium-density gray acrylic foam tape with high performance acrylic adhesives on both sides and a red release liner. The tape uses automotive OEM (Original Equipment Manufacturer) approved acrylic foam core and adhesive technology. 3M 6394 is characterized by high peel and shear adhesion, high internal strength, high conformability and excellent plasticizer resistance. Designed for reliable attachment of a wide variety of automotive exterior and interior trim including running boards, ground effects, claddings, rocker panel moldings, spoilers, wheel flares, bumper trim and other larger or heavier automotive trim components."
i noticed a slite mpg improvement. but a major improvement in safety. passing semi's dont blow me all over the road. i highly recommend. layout i m glad i dont have barn doors because i know i would have done same thing.
no pink that is your trademark i wouldnt want to be sued.
i did paint some black for around my bumper and some silver for my toolboxes.
What a great safety feature. Of course someone would install them backwards and the left side would blink for a right turn. Probably wouldn't be such a great idea after all.gotta go i was waiting for them to come out with turn signal airtabs. You know the whole side of truck blinking
Mine are lavender/blue, which is another thing I like: they are easily painted, [with Krylon Fusion for plastic], adding a bit of color to the truck, without the expense of graphics.
PS It's only been a few months, but I haven't lost one from the roof yet....
