dont idle is a big one and make sure you are using the correct mb number oil,,alot of people think they are but are using the wrong oil {mobil one esp not just any mobil one oil}. i got 300,000 out of my dpf before it got plugged in my 2007 sprinter, and i removed it and sent it away and got it cleaned for around $500 including the shipping
No way I would idle all the time your just asking for trouble. Get a espar or buy a good generator and a portable a/c and a heater.
Briggie,
Did you un-install that part of exhaust system yourself?...this was my original plan but I could not see how to disconnect at engine block on 2010 model...freight liner told me they put 12 man hours into un-install/reinstall and that it booked at 8 hours.
Labor was the killer for me. I was originally told it would be about $250 for this procedure....Imagine my surprise.....
I thought the dealership could burn the filter clean via the ECU. They can make it over heat for the cleanning. Also, the ECU should burn it when a clog is detected. That was the plan?
If you've already got an Espar....Thermo King has a special running...$799.00 for an upgrade installed....2011 Sprinter 320K mi. - 19.4mpg light load.
Summer I leave her idling with Air on for my Dog while I run in and out
of Shipping/Recieveing/Restroom/FastFood (no dilly dallying )
Other than that, NO IDLING.
Air Conditioning is Roof Top using Generator on swing-out rear hitch.
Heat is Espar D2 Bunk Heater...moving up to a D4...approx.1 Gallon Diesel used/24 hrs..
I included photos below of the Mobil 1 Correct Oil and it's Part Number. Buy it thru NAPA and when On Sale
purchase it for $5.99, otherwise it's about $9+/quart.
Diesel Exhaust Fluid I refill at the Truck Pumps for about $2.69/gal..
I thought I read a while back that the filter/soot has to be heated up and exhausted every approx. 300mi., so obviously you gotta get your rpm's up out there on the highway 65-70mph. Gotta Burp the Baby!
Thank you Ken for that info.. That seems like a fair price just for a Heater Box Upgrade/install.If you've already got an Espar....Thermo King has a special running...$799.00 for an upgrade installed....
