Glow plugs either work or they don't. They are like a light bulb, either they come on when you flip the switch, or they don't come on if they are burned out. The vehicle will start without glow plugs, it's just that the colder it is the harder it will be to start, since diesel combustion requires heat and pressure, and a cold engine won't have much heat until it's turned over a few times. You may only have some of them that have failed, not all of them.
Good news is the glow plugs are cheap ($36 list at a dealer). $13.06 each at Rock Auto (the Bosch #80036), $18.50 at Europarts.
Bad news is the glow plug control module will also need to be replaced, since a burned out glow plug will take out the module (and it's also why when one glow plug goes out, you replace all of them at once, because you don't want to replace one, and the module, and then the next week another plug goes out and takes the module with it again). But there's good news there, too, since the new glow plug control modules (third revision) are now solid state with no internal fuses to blow, so when a plug goes, you replace the glow plug and clear the module error code and you're good to go. Bittenbinder has the new module, so does Europarts and almost certainly the Mercedes dealers ($215 list, $164 at Europarts, and I think it's right at $150 from Bittenbinder). Many of the Dodge dealers only have the older modules available to them when they get them through normal channels. You're better off ordering the parts yourself, unless you have the plugs and module replaced by Bittenbinder.
If this were March, you could wait until the fall to replace the glow plugs, but you really don't want to go very long during the winter without functioning glow plugs. In fact, when it's really cold, in the teens or colder, it's a good idea to turn the key on and let the glow plugs heat the engine, and when the glow plug light goes out, turn the key off and then back on and let the glow plugs heat the engine again. The warmer the engine when starting the less stress there will be on the pistons, rings, and injector seals.
