Yeah, 'cause everything else about a Sprinter makes perfect sense.
LHM due to dirty EGR valve. Then they cleaned the EGR valve, and when they resinstalled the EGR valve the stripped the bolt holes on the EGR valvle, which caused not only a coolant leak but a boost pressure leak. Repaired bolt holes, coolant leak stopped, pressure leak gone.[/QUOTE
Nope, I was in limp mode when I took the vehicle into Courtesy. The limp mode was not caused by anything they did. I took it there to have it scanned, there was an EGR code, and I had them clean the valve. I was pointing out that I only developed the coolant leak after they took the EGR off to clean it, and the problem with the coolant leak was properly diagnosed by the tech in Knoxville who ultimately put the new EGR on. When he tried to tighten the bolts down, they would not tighten. It was then that he discovered the holes had been stripped and pointed out that that was the reason I had been losing coolant.
