RE: Would a 16ft to 20 Ft Cube van work Expediting
Great points on cube vans. Keep in mind that most cube vans are 1 ton vans with a portion of the thin sheet metal "cut-away". A "box" is attached to the frame in lieu of the removed sheet metal. The box is much heavier than the metal.
Normally, one ton vans have a weight carrying capacity of 3500 lbs (before the driver and his belongings are placed in the van). The GVW on a typical one ton van is around 9,500 lbs, keeping them under DOT regs and the Hours of Service (logging) regulations. One ton vans typically weigh around 6,000 lbs. empty. Add in the weight of the "box" which was added, the weight of the driver, and the weight of his or her belongings, you now have a "van" that weighs around 7,500 lbs (or more) empty, and still has a GVW of 10,000 lbs. Add belongings, driver.... you get the idea - 2,500 lbs. load carrying capacity.
You can NEVER change the GVWR rating on a truck by adding air bags, different spings or the similar. The only time the weight (load) carrying capacity of a (straight)truck can change is if a "tag axle" is added to the vehicle. The tag axle itself has it's own GVWR tag. The weight tag inside the driver's door of the truck is combined with the weight tag on the tag axle for a new combined GVWR. The axle weight laws themselves in many states will not allow full usage of "proposed new GVWR". An example is a standard 33,000 GVWR straight truck. Add a tag axle which has it's own GVWR tag of 22,000 lbs. Can you now have a legal ride with GVWR of 55,000 lbs? NO, the axle laws will most likely limit you to 46,000 lbs.
Should you exceed the manufacturer's GVWR of the 10,000 lbs total, you are then required to log. You may also be subject to fines should you be stopped, scaled and found to exceed the GVWR plate located inside the driver's door of the vehicle.
I think it is very important, before you purchase a cube van (cut-away), that you research the carrier you are intending to lease it on to. Find out if more of their loads require volume capacity or weight carrying capacity. If more van loads are heavy, buy a typical one tone van. If their customers require more volume, buy the cube van. To get the most out of a cube van, purchase one with GVW in excess of 10,000 lbs, such as a good 14,000 GVW. You will get the best of both worlds - volume and weight carrying capacity. Sure you'll be required to log, but the few moments it takes you each day to prepare the log will be well worth it!
Thanks,
HotFr8Recruiter
