Will March 19 'Supermoon' Trigger Natural Disasters?
Space.com space.com – Thu Mar 10, 10:15 am ET
On March 19, the moon will swing around Earth more closely than it has in the past 18 years, lighting up the night sky from just 221,567 miles (356,577 kilometers) away. On top of that, it will be full. And one astrologer believes it could inflict massive damage on the planet.
Richard Nolle, a noted astrologer who runs the website astropro.com, has famously termed the upcoming full moon at lunar perigee (the closest approach during its orbit) an "extreme supermoon."
When the moon goes super-extreme, Nolle says, chaos will ensue: Huge storms, earthquakes, volcanoes and other natural disasters can be expected to wreak havoc on Earth. (It should be noted that astrology is not a real science, but merely makes connections between astronomical and mystical events.)
But do we really need to start stocking survival shelters in preparation for the supermoon? [Photos: Our Changing Moon]
The question is not actually so crazy. In fact scientists have studied related scenarios for decades. Even under normal conditions, the moon is close enough to Earth to make its weighty presence felt: It causes the ebb and flow of the ocean tides.
The moon's gravity can even cause small but measureable ebbs and flows in the continents, called "land tides" or "solid Earth tides," too. The tides are greatest during full and new moons, when the sun and moon are aligned either on the same or opposite sides of the Earth.
According to John Vidale, a seismologist at the University of Washington in Seattle and director of the Pacific Northwest Seismic Network, particularly dramatic land and ocean tides do trigger earthquakes. "Both the moon and sun do stress the Earth a tiny bit, and when we look hard we can see a very small increase in tectonic activity when they're aligned," Vidale told Life's Little Mysteries, a sister site to SPACE.com.
At times of full and new moons, "you see a less-than-1-percent increase in earthquake activity, and a slightly higher response in volcanoes."
The effect of tides on seismic activity is greatest in subduction zones such as the Pacific Northwest, where one tectonic plate is sliding under another. William Wil****, another seismologist at the University of Washington, explained: "When you have a low tide, there's less water, so the pressure on the seafloor is smaller. That pressure is clamping the fault together, so when it's not there, it makes it easier for the fault to slip."
According to Wil****, earthquake activity in subduction zones at low tides is 10 percent higher than at other times of the day, but he hasn't observed any correlations between earthquake activity and especially low tides at new and full moons. Vidale has observed only a very small correlation.
What about during a lunar perigee? Can we expect more earthquakes and volcanic eruptions on March 19, when the full moon will be so close?
The moon's gravitational pull at lunarperigee, the scientists say, is not different enough from its pull at other times to significantly change the height of the tides and thus the likelihood of natural disasters. [Infographic: Phases of the Moon Explained]
"A lot of studies have been done on this kind of thing by USGS scientists and others," John Bellini, a geophysicist at the U.S. Geological Survey, told Life's Little Mysteries. "They haven't found anything significant at all."
Vidale concurred. "Practically speaking, you'll never see any effect of lunar perigee," he said. "It's somewhere between 'It has no effect' and 'It's so small you don't see any effect.'"
The bottom line is, the upcoming supermoon won't cause a preponderance of earthquakes, although the idea isn't a crazy one.
"Earthquakes don't respond as much to the tides as you'd think they would. There should actually be more of an effect," said Vidale.
Most natural disasters have nothing to do with the moon at all. The Earth has a lot of pent up energy, and it releases it anytime the buildup gets too great. The supermoon probably won't push it past the tipping point, but we'll know for sure, one way or the other, by March 20.
EnglishLady
When I read this article this morning, I had a chuckle thinking about all the ppl that read (and believe) their stars everyday.
Wow what a spin they must be in right now :D:D
Sue stole my SuperMoon induced thunder :D , but the above is all you need to know, really.
The last Supermoon, supposedly 18 years ago, was supposed to trigger massive earthquakes, particularly that along the New Madrid fault. Didn't happen. Whoops.
The fact is, Supermoons (Lunar Perigee) occur all the time, pretty regular. There are 4-6 SuperMoons a year, every year. It's in the stars.
The one on March 19, 2011 is in fact the closest SuperMoon of the year, but it's not by any means the first one in 18 years, nor even the first extreme SuperMoon in 18 years. March 19 will be already the second SuperMoon this year, and we only have to go back to January 30, 2010 to find the last example of an extreme SuperMoon.
People have historically pointed to these SuperMoons and severe weather or some other natural disaster as a causal link between the two, yet there is no real actual link at all. For every earthquake or really bad snowstorm that happens during a SuperMoon, there are dozens or hundreds of them that happen on days where a SuperMoon does not occur. People will say things like, "previous SuperMoons took place in 1955, 1974, 1992 and 2005, all years that had extreme weather events." And they are correct. But we've had plenty of extreme weather events during years where no SuperMoons occurred.
People are already saying, I'm sure, that the volcanic activity in Hawaii is related to this, because, you know, Hawaii hardly ever has any volcanic activity. I'm sure if they aren't already, some will put the earthquake in Japan, and the associated tsunami as a consequence of this, because, you know, earthquakes in Japan hardly ever happen. In fact, the only time the planet experiences sever weather or other natural disaster is during a lunar perigee OMG we're all doomed.
The chart above is what the Moon did in 2010. The closest approach was on January 30, which was 356592 km away from the Earth. The one next week will be 356577 km away from Earth, fifteen whole kilometers closer.
So batten down the hatches people, we're in for a rough ride. <snort>
EnglishLady
ROFL, sorry about that :D:p
I just though it was funny that we both chose that one part of the article to focus on.
Great minds, and all that. :D
jimby82
Like ... that ... would ... make ... a ... difference?
Science, ain't it great!
and here I thought it was your "magnetic" personality...*l*
Naw, I don't have a 'magnetic' personality, I have an 'electric' personality. It is ALWAYS 'shocking' when you meet me!! :p Man, you can sure tell I had 4 cups today and a good nights sleep, eh? :D
