Hello, the best of luck to you in your endeavors.As far as a pickup truck for expedited use, the only company that I know of that will take one is CTX out of Michigan.I have worked for some local expediting companies out of Cleveland, Ohio, that also use them as well.The guys there used to make wood sides about 4 ft high and the same with the front, connect it all together, and leave the back open, then have a tarp co such as the one in Bradner, Ohio, make a tarp large enough to cover the sides, top and back, and bungee cord it to the sides and back. It works real well, and freight does not get wet with this setup, surprisingly.
