Having no truck payment is the key to success in a van. You can squeak buy with a payment, but you will have a payment due every month on top of breakdowns. At least if you pay cash for your van, all you have to do is put 5k away in a reserve account to cover breakdow or the purchase of a new van in the future. I bought my current van for 5500 dollars and spent another 1500 in tires, transmission flush, oil change, differential change, tune up, 1 lower ball joint, and 4 new tires and an alignment. I've already put 15 thousand miles on it without a hitch.
Freight levels are picking up again; Bolt is actually saying that they are going to raise the rates up a bit in the next couple of weeks if capacity continues to tighten. You can do well in a van if your expectations are reasonable. I'd say you can take home anywhere from 25k to 35k after expenses if you are leased on to a company that will run you good, and if your equipment is paid for. You also have to spend time on the road. You are your own boss on this job, you decide when and where you want to work, but you must be dedicated to the road to be able to make a good income. I usually stay out between 6-12 weeks at a time and then take 2 weeks off. I also take off a lot of time during the winter season.
You just gotta run the numbers. I'd say it costs me 39 cents per mile to run my van right now and my company has been paying me an average of 86 cents per mile loaded. If I do 6k miles in a month, that is 5100. My operating cost for those miles are 2k that means I take home 3k. Out of that 3k I need to take out another 400 a month for food on the road, 100 for cellphone, and 120 for bobtail and personal injury insurance. That leaves me with 1480 after all those expenses. Also keep in mind that the 2k for van operation is money for fuel and money that I save for maintainence. This is because I do not have a van payment. You can technically say that I am probably going to net 2k a on a 6k mile month. So, the true question is; can you live on 1400-1500-2000 a month take home?
There are months where you will run 10k miles, and also months where you will be lucky to get 3500 miles. I just gave you an example of a regular month. 6k miles should be a regular month out here. I have done 3k miles so far this and we are only on the 13th day of this month, I also did 8k miles last month. So, as you can see, my numbers are lower than what might or might not happen when you are working. Just read up on some older threads in here and make a very informed opinion on what you want to do! You are going to drop 100k miles on your van the first year out here...never buy new and pay depreciation. After you get a couple hundred thousand miles on your van, no one will want it; not even the repo man!
I hope this helps.
