I built a spreadsheet in excel format to calculate how much you make PER HOUR.
The board does not like .xls ( spreadsheet ) files, so it has a ".txt) extension. After downloading it, rename it to .xls to get it to open in excel, libre office, or any other program that can use the ms excel spreadsheet format.
The input highlighted in yellow is your TRUE cost per mile. Make sure it includes everything from fuel to depreciation expressed as a "per mile" cost in dollars.
The left column is written in pay per mile, expressed as cents not dollars.
The top row is miles per hour.
The data in the table is "dollars per hour".
You can alter the "speed" row and "per mile" column numbers. The table isn't locked in any way so you can tweak it to your liking. Just change the yellow highlighted to your actual costs per mile.
I hope this is useful in some way to you, I wanted to know this.
