>I've got a question you can ask while calling around. When
>it says "All trucks over 7000 Pounds" do they mean actual or
>gross? I never know. So I just pull in. I'd rather be told
>"stay off my scale" than "you should have pulled in, here is
>your ticket please follow me to the scale".
Made some more calls on Monday, and Iowa was one state I called, since they have been a topic in the past. I talked with a semi rude Sgt. with Commerical Vehicle Enforcement, and he explained that cargo vans DO NOT need to weigh in Iowa. They only want TRUCKS to weigh. I explained to him, that my cargo van is registered as a truck, and he informed me that Iowa considers a TRUCK a vehicle with a weight listed on the side. So you don't need to worry about Iowa...
...but you do need to worry about Kentucky! In KY, they consider a truck anything, "... from an S-10 to a Volvo!". Passing a scale in Kentucky, in a cargo van, could, I repeat, COULD cause the DOT to come after you. They (KY) considers it a moving violation, to pass a scale, and the fine is $100.00.
I don't want to nickle and dime this, so I'm trying to get as much info put together, as quickly as possible, so I can post everything at once.
Happy Motoring!
