RE: van, My response above:
Streetsweeper's ball-joint test technique is one I often used back when I repaired automobiles for a living. This thread reminded me of a tool I still own but nearly forgot about. It's called a dial indicator, made by Central Tools, Inc. Back in the day, I used it every time I diagnosed a faulty ball joint, tie rod end, or out-of-round disk brake rotor.
With this tool, I was able to measure the precise amount of free play a ball joint or tie rod end had, and compare it to the factory specs. To check ball joints, I did exactly what Streetsweeper says to do, only with the dial indicator attached. With the dial readings in hand, no customer of mine ever had to wonder if my recommended repair was actually needed, and I never had to worry about a customer, competing shop, or secret shopper, or undercover news reporter later saying I made an unecessary repair. I wrote the dial readings on the service order along with the factory specs.
That was about 20 years ago. Checking today, it was fun to see the company is still going strong under the same name, at the same location, selling the same tools. No price is published on their web site, but I'm sure the tool is expensive. It's a very high quality precision instrument. If you are in the business of repairing vehicle front ends and disk brakes, it might be worth buying. Otherwise, Streetsweeper's technique is more than adequate.
Tool photo attached
Central Tools, Inc. web site is:
http://www.centraltools.com/tools.html
To use the tool, you attach the modified vise grip to any sturdy vehcile component. Attach the snake to the vise grip. Attach the dial to the other end of the snake. Position the dial plunger on the questionable component. Tighten the snake to hold the dial firmly in place. Zero the dial. Move the component through the full range of its free play. Note the dial reading.
Then, in the customer waiting area, and hopefully in front of other customers, place the tool in the customer's hands and demonstrate how you used it in diagnosing the faulty component. When they return to their work or neighborhood picnic, you are likely to benefit from some word of mouth advertising.
