Van shocks
I've got 93k on my original shocks. I suspect 100k is pretty much the useful life for OEM shocks so the questions are:
What kind of mileage did you guys get on OEM shocks?
What did you replace your OEM shocks with?
chefdennis
I got 200,000 on the 05 CV...the new 1, 58,600 ant the rt ft is bad...ill be replacing both this week...oh I'll be putting Monroes on, old habits are hard to break...
377,000 miles on the OEM shocks, front and rear. 273,000 on the Napa replacements that are due for replacing.
OK, sounds like I'm probably about 1/3-1/2 way through my original shocks then unless something unexpected happens. I figured when I did replace them I'd probably go with Monroe but wasn't sure if they were still top shelf or not and also if I go with them if there's a specific model better than the rest.
Some shocks need replacing at 60,000 miles, some at 300,000. It's a wear part, not a timed part, so it all depends how often you get to drive in and around Detroit.
blizzard2014
I just replaced my shocks after 160k and the van rides loike a tank now. Before that the van was almost going out of the lane every time I hit a bump on the road.
guido4475
Mine were replaced around 40k ago.Fronts are like sponges.Getting replaced asap.I put Monroes on it last time.Ford originals are going back on it.Rode alot better, more control.
danthewolf00
Koni's specal d red shock on rears and oem on front after 225k.... Front is getting soft again after 150k but rears just need to be turned up in strenght.
Jason2
Come on down to bama on hwy 43 out of Lawrenceburg Tn.. talk about rough.
