My van came with a semi padded rubber mat that has carpet pad type material under it. I think that's going to have to come out to avoid insufficient clearance from the plywood for the 48" mandatory door clearance. I hate to lose the insulating and noise reduction benefit but see no other option. That means the plywood will go on the bare metal floor. Do I need to bolt it to the floor or is screwing it down sufficient? Should I put a bead of glue along each rib it will lay on? How many screws/bolts is typical?
Does anyone offset the plywood from center? I was looking at it with the sheet laying so the edge was along the edge of the trim piece of the side door, about a 1.5" offset to the right. That still leaves about 2" clearance from the right door frame but also gives a little more room along the driver side wall to store personal stuff.
