Truck Generator of the future!
Humble2drive
We had the good fortune of meeting Dr. Patricia Irving, President and CEO of
InnovaTek Inc. InnovaTek™Incorporated when we transported her “baby”
to GE Research and Development one year ago.
We have since followed InnovaTek’s progress in developing mobile applications of their fuel cell technologies which can be used to provide clean, quiet energy production for DOD applications as well as commercial trucking.
Imagine a generator for your truck that is:
Silent.
The size of a suitcase.
Able to generate from 1kw to 50kw.
Able to utilize any carbon based fuel source. (Biodiesel, gasoline, diesel)
Able to operate usng an environmentally “clean” non-combustable approach.
If you are a Geek or just interested in what new technologies are being developed to make life easier on the road then
Click here to see specs and pics:
http://www.tekkie.com/docs/InnovaGen.pdf
Just thought it was worth sharing.:D
redytrk
The date of initial publicity on this unit was 2008. apparently nothing has happened in the meantime.
Actually this is a fuel processor to produce hydrogen for fuel cells. It is a step in the right direction but a little short of a generator.
Webasto has an actual fuel cell generator that operates on methanol, it is finally coming here to the states after being in the EU market for 2 years.
Humble2drive
Maybe the link didn't work for you??
The Innovagen is the mobile "generator" that utilizes the hydrogen fuel cells to produce electrical energy from chemical energy. They are focusing on between 1-50kw for the mobile applications. This is the range that the military is very interested in. The link has pics of a complete unit as well.:)
Humble, it is a fuel processor and a great thing to have and great our tax money was able to help get it going.
However it is not a fuel cell, it doesn't produce the electricity but provide the hydrogen to the fuel cell which is very very important. The link works, the cut sheet was clear on the purpose of it, but regardless it is our future and like the webasto fuel cell it will be a great thing to have for the truck.
Humble2drive
Greg334:
My bad, the link is limited and does not mention the partnerships (mostly military) and the integration of the various components.
Any links to the Webasto fuel cells would be of interest.:D
I like the idea of "silent" and "clean" generators that could have the potential to shut up the CA environment radicals. (regarding idling anyway);)
Humble2drive
You have any info on when this product will hit the market? price? any other info?
Thx
I ran this question by Dr. Irving. Her reply:
" . . .The system is in a prototype stage and is undergoing tests by truck equipment manufacturers.
Thank you for your interest and support.
~Patricia
Patricia Irving, Ph.D.
President & CEO
InnovaTek, Inc."
My translation: There are some working models in use which may or may not resemble the ultimate finished product. It will be quite some time before it reaches the market.:confused:
The EFOY 2200, the big one, produces 2200 12-volt Watt Hours per day. That's 180 amp hours per day, or an output of 7.5 amps at 12 volts, which is 90 Watts. Aside from the fact that you must use Webasto's own "ultra pure" methanol, which is very expensive and hard to find (relatively speaking, West Marine - $18 a gallon), the unit is designed and positioned to be something along the lines a little bit more than a smart trickle charger. It will not replace a generator. It is used to charge batteries.
It cuts in at 12.3 V and cuts out at 14.2 V (both values can be set by the user). 12.3 V is about 70% charge, so there's at least 30% which it needs to replace. It can run at most 24 hours per day to do that, so that determines the max size of your battery bank. The EFOY 2200 is 90 Watts with an output of 7.5 amps. Which is suitable for a lead-acid, lead-gel or AGM battery bank of up to 300 Ah. And that assumes that you never, ever draw the battery bank down below 50% DoD, which is 150 Ah per day, since it will take at least 180 Ah flowing into the battery bank to get 150 Ah back into it.
Most people out here in expediting would do well on 150 amps hours per day, as LED or florescent lights, a laptop, Espar heater and maybe a television, will not use quite that much, depending on how long you are awake and sitting with everything running. The stuff listed here is about 5-8 amp hours, so it just depends on how many hours you'd be running everything. At most it's good for about 18 hours, tho.
Add in things like a microwave, coffee maker, and the EFOY cannot keep up. You would have to supplement the EFOY with shore power, an external generator, the vehicle's alternator, or solar panels.
If you had room, and the proper amount of sun, you could get the same number of amp hours from solar panels as you would the EFOY, for about five grand, which is half the cost of the EFOY, not including the "ultra pure" methanol which gets used at relative low rate of about 1/2 liter per day, about 1 gallon per kilowatt hour, so one gallon should last a week or 10 days (which translates to about $2.50 per day, which isn't very much, really, but it adds up).
But it's that upfront cost that gets you, and it takes a lot of years for it to pay for itself. Even the smallest EFOY 600, which is 50 amp hours per day and 2.1 amps, will cost you $4,200.
The EFOY fuel cell should be thought of as a small, albeit high dollar, battery charger, are not a complete replacement for a genset, charging alternator, or even solar panels, especially if you have heat resistive appliances like air conditioning, refrigerator/freezer, rice cookers, coffee makers, etc. It is also not a replacement for a battery bank. Duh.
Still, I like the direction that fuel cells are headed. Webasto has a 1000 Watt diesel APU/fuel cell thing they are working on, which will be enough to charge a 400 amp hour battery bank, and/or power a 12 volt rooftop air conditioner (like the one from Espar of Michigan) and will use about as much fuel as an Espar heater. No word on pricing.
14Wheeler
Hey Turtle !!
Need your battery knowledge for a sec.
I've run a 12V A/C system since late Sept of last year. With the 4 PowerRush Platinum AGM batteries, I am currently almost doubling what Arctic Breeze says is run time 8-10 hrs off full charge.
Now , if I were to invest in another oposing side battery tray, and run eight batteries, would that mean I could go double my current 14-17 hours ?
Im no artist, which drawing do you think's the correct way to wire the eight ?
And i'd probably need to re-invest in an upgraded battery isolator ? And battery management control panel ? Just wondering how you'd do it ? I wired up the current supply bank with a bunch of #2 to batteries and #0 to alternator.
ebsprintin
I was wondering where this technology went. I was following some of the companies that were developing this about 10 years ago. The key was that any fuel could run the process. Great for vehicles. But somewhere along the way instead of using existing fuels like gasoline and deisel, the only ideas that hit the public was cars that need a hydrogen tank and a whole new hydrogen supply system.
eb
First, let me apologize to all.
Hey Turtle !!
I think the Arctic Breeze 8-10 hours of running time is for a 50% DoD. If you're doubling that, then your battery bank is twice the amp hours of the base system, or you're running the batteries down too low.
In any event...
Yes. Doubling the amp hours will double the available amps. Actually, taking the Perkuet Effect into account, if the amp draw stays basically the same, you'll actually have more than double the amount of available amp hours.
Neither. Wiring Positive to Negative increases voltage. If you have eight 12-volt batteries, and wire them Positive to Negative (in a series, as with the second drawing), you wind up with, in effect, a single 96-volt battery.
Let's assume 6-volt batteries, however. In the first drawing, you have two sets of four, with each set being wired in a series so that each set of four is a single 24-volt battery, and then those two sets are wired in parallel to double the amp hours, giving you one large 24-volt battery.
What you want to do is wire them Positive to Positive, and then Negative to Negative, which is a parallel configuration, which doubles the amp hours, but keeps the voltage the same. Every time you add another battery in a parallel configuration, the voltage always stays the same, but the amp hours of each battery gets added together.
If you have a bunch of 6-volt batteries, you'd connect one pair in series as positive to negative, to turn the pair into a single 12-volt battery, and then do that for all the other 6-volt pairs, then connect each of the 12-volt series batteries in parallel to start adding up all the amp hours of the batteries, while keeping the voltage to 12-volts.
There are four basic ways to wire up multiple batteries:
Method 1
Notice that the connections to the main installation (Main Installation being either the charging source, or the draw connection, i.e., inverter or busbar distribution) are all taken from one end of the battery. The interconnecting leads will have some resistance. It will be low, but it still exists, and at the level of charge and discharge currents we see in these installations, the resistance will be significant in that it will have a measurable effect.
You can use really large cable, which will have
a resistance of as low as 0.0002 Ohms, so the 6-inch length between each battery will have a resistance of 0.00012 Ohms. Practically nothing, I know. But add onto this the 0.0002 Ohms for each connection interface (i.e. cable to crimp, crimp to battery post, etc.) and you end up with the resistance between each battery post is around 0.0015 Ohms. Four batteries with 8 terminal posts, and you have .012 Ohms, and that's just to interconnect them. It doesn't include the resistance of the connections to the alternator, fuses, inverters and/or busbars.
So, the key is to use cables large enough to handle not only the amp draws expected, but also to minimize resistance, since resistance increases heat and decreases voltage, thereby making the batteries work harder and thus giving you less amp hours to work with.
The Method 1 above shows the installation connected at one end of the bank. If you pulled 100 amp hours out of the batteries, one would think we're pulling 25 amp hours from each battery. And that would be wrong.
In actuality (and I can provide the mind-numbing, nap inducing mathematics if you like), what's happening is this:
The bottom battery provides 35.9 amps of the 100 amps.
The next battery up provides 26.2 amps.
The next battery up provides 20.4 amps.
The top battery provides 17.8 amps.
So, the bottom battery provides more than twice the current of the top battery. When charging, the reverse is true, where the bottom battery is subjected to more current and voltage, and the top battery gets the leftovers. The bottom battery is being worked over twice as hard as the top battery. The effects of this are rather complex and do not mean that the life of the bottom battery will be half that of the top battery, because as the bottom battery loses capacity quicker (due to it being worked harder) the other three batteries will start to take more of the load. But the net effect is that the battery bank, as a whole, ages much quicker than with proper balancing.
Now on to Method 2
Method 2
All that has changed in this diagram is that the main feeds to the rest of the installation are now taken from diagonally opposite posts, from battery #1 and battery #4.
It is simple to achieve but the difference in the results are truly astounding for such a simple modification. The connecting leads, in fact, everything else in the installation remains identical. Also, it doesn't matter which lead (positive or negative) is moved, whichever is easiest is the correct one to move.
The results of this modification, when compared to the original diagram are shown below. Only that one single connection has been moved. After this simple modification, with the same 100 amp load:
The bottom battery provides 26.7 amps of the 100 amps.
The next battery up provides 23.2 amps.
The top battery provides 26.7 amps.
Such a simple and effective change, but one that hardly anyone employs. Drives me crazy. The batteries are much closer to being correctly balanced.
However they are still not perfectly balanced. How far is it necessary to go to get the matching equal? It depends. In a massive installation, like in a home that's off the grid, or in some ultra critical installation, it's very important to have the batteries all perfectly matched. But in a 4-battery setup, Method 2 is fine. In an 8 battery setup, I'd split it into two connections, where you'd connect the four batteries together as in Method 2, then do the same for the other four, and then connect those two together.
Now on to Method 3
Method 3
This looks more complicated, but it's not. And it's very similar to how you'd connect 8 batteries, in sections of 4 each, actually.
It is quite simple to achieve and requires only two extra interconnecting links and two terminal posts. It is important that all 4 links on each side are the same length otherwise one of the main benefits (that of equal resistance between each battery and the loads) is lost.
The difference in results between this and the 2nd example are much smaller than the differences between the 1st and 2nd (which are enormous) but with expensive batteries it might be worth the additional work. Most people don't consider the expense and time to be worthwhile unless expensive batteries are being fitted or if the number of batteries exceeds 8. Plus, this method isn't always so easy to install because of the required terminal posts. In some installations there is simply no room to fit these
To achieve the same results in a much easier to install configuration, we have Method 4:
Method 4
Again, it looks odd, but it's actually quite simple. What has been done here is to start with 2 pairs of batteries. Each wired in the proper "cross diagonal" method. Then each pair is wired together, again in the cross diagonal method.
Notice that for each individual battery, the current always goes through a total of one long link and one short link before reaching the loads.
This method also achieves perfect balance between all 4 batteries and may be easier to wire up in some installations. It costs more, obviously, because of the additional cables and cable lugs.
There really is no excuse whatsoever (except perhaps incompetence or laziness) for using Method 1 given at the top.
The other three methods achieve much better balancing with the final two achieving perfect balancing between all four batteries.
Interconnecting batteries is just one of those rare things where doing something the correct way actually looks less elegant than doing it the wrong way.
Of course, if you only have 2 batteries, then simply linking them together and taking the main feeds from diagonally opposite corners cannot be improved upon.Method 2 is to be used for 3 or more batteries. With a large number of batteries it may be necessary to go to the 3rd method or 4th method. But even with 8 batteries it is possible to get reasonable balancing by placing the main "take off" feeds from somewhere down the chain instead of from the end batteries. Remember, count the number of links each battery needs to run through to reach the final loads and get these as equal as possible.
If your battery bank has various take off points on different batteries, where you have this 12-volt thingy connected to one battery's terminals, and another 12-volt thingy connected to another battery's terminals, stop doing that. Change it now! Not only is it is extremely bad practice, it's retarded. Not only does it mess up the battery balancing, it also makes trouble shooting very much more complicated, and it looks just awful.It truly looks like it was installed by someone who doesn't know what they are doing. Be a man and get a busbar. Do it right.
Finally, the charging source should always be connected to the same points as the loads, a.k.a., the inverter or the busbar. Without exception.
Upgraded battery isolator? I dunno, what kind do you have now? A 100 amp isolator will probably work, although a 200 amp isolator would be better.
As for a battery management console, a Xantrex Battery Monitor is the way to go. It monitors all amps in, all amps out, voltage in and out, depth of discharge, battery temp (if you add the optional temp sensor), and time to discharge at the current draw. There are more expensive battery monitors, and the Xantrex isn't cheap, but thy won't tell you anything more than what the Xantrex will.
I've got #2/0 Cobra brand (no, not that Cobra) Ultra-Flex cable (way more flexible than welding cable) with Panduit cable lugs made specifically for that Cobra cable. The cable from the alternator to the batteries could have been #2 cable, or smaller, but to keep the voltage drop to a minimum on that length of cable, I went with the #2/0. The interconnecting cables, and the cables to the busbars and the inline fuses, are also #2/0 cable. I'd have gone with #4/0 cables and lugs just to further minimize the voltage drop (Ohm resistance), but the lugs alone were gonna be like $9.00 each, and I'd need like 30 of them.
The busbars I use are thicker than I need, but again that's to minimize resistance. I use the one with the four stud bars, but if you have a lot of 12-volt loads, they have an 8 stud bar as well. Two or three connections can be made at each stud, so 4 was enough for me. It also has four #8 screws for connecting smaller loads. ( PowerBar 600 Ampere Common BusBars - Blue Sea Systems)
100 amp busbars would work for most people, 250 amp busbars would further reduce the resistance, mine is the 600 amp busbar.
Fuses are Class-T (Class-T Fuses - Blue Sea Systems) with heavy duty fuse blocks (Class T Fuse Blocks - Blue Sea Systems)
Some people use SEA or ANL fuses, and that's fine, but in a multiple battery installation with an inverter, Class-T is what you want, because of their extremely fast short circuit response and smothering capability. SEA fuses are OK in lower amperage situations, but they are known as the "economical" alternative.
Here's the thing about "economical" alternatives in a situation like this. Look at all of the batteries in the bank, and then add up the Cold Cranking Amps of each. If you have four batteries, each with 800 Cold Cranking Amps, if there's a short circuit, like a cable that ends up rubbing on the vehicle frame, then that's a cool 2400 amps that gets fed into the short. That's enough to blow the bottom out of the truck.
What you want is a fuse that has microsecond response time, and that means a Class-T fuse. ANL is OK, but it won't have nearly as fast of a response time. In a situation where a short causes a 600% load over rating, an ANL fuse will blow in about 1/10th of a second. A Class-T fuse will blow in less than 1/100th of a second.
At lower currents, like 200% above rating, which can occur in some inverter load start ups, you don't necessarily want the fuse to blow as fast, and the Class-T fuse won't blow at 200% until after about 50 seconds, whereas the ANL fuse will go ahead and blow at about 2 seconds. So basically, Class-T fuses will blow exactly when they need to, and won't give you a lot of annoyance blows like ANL fuses will. After a couple of annoyance blows, the cheaper ANL fuses suddenly cost more than that Class-T.
14Wheeler
Wowser, this is the mother-load of answers ,GRACIAS !!
Was not certain the Perkuet effect would apply. My wiring config errors were based on the fact I was ignorantly assuming Ohms Law series-/parallel+ was the way to go [dont ask :D]
Having more than double the storage will probably be more than
enough to push me into a get-it-done state.
To me, your number four diagram makes the most sense to me. For one, could remove any battery without interupting the circut. And kuddos on the balancing stuff. Was clueless.
I got some so called competition lugs from a high end car stereo installation shop. Nicest lugs i've ever seen and secure like nothing i'd ever seen before. Always heat shrink 2+ inches up from the ring terminal. I've already got a single PAC (PAC200) 200 Amp isolator. Swapped out all the hardware of the isolator and fitted it all with gold plated non-corrosive mount,washers,nuts.
Going to have to purchase the monitor. Can secure a new Xantrex TM500A for around $150. Probably way overkill,
but can be had for 1/2 retail.
Fuse holders/fuses/busbars and the lugs are all that Scosche fancy car audio compitition stuff. Super heavy duty with great mounts and corrosion free hardware. I'd just have to repeat what i did on the new replacement batteries. With the variety of blocks, i'll have no problems with chaining or feeds. Some of
the blocks have up to 4-6 inputs and handle up to #00. I did measure exactly the length of cable i used for each battery. Good to hear that was needed.
So no issues with #2 on the batteries and staying with #0 for the alternator/isolator?
Cannot thank you enough for taking the time typing all this info up. Googles a great tool but sometimes i'd rather follow the advice from someone who's actually been there. Could anything be better than 20+ hours of noise free,vibration free, ice cold relaxing ?
And to think, I kept it brief. :D
If adding additional batteries to the ones you've already installed, don't pass Go, don't collect $200, do it now, sooner the better. Adding newer batteries to old batteries is the surest way to kill the new batteries. Much better to add them all in one whack. As batteries age, even if they've been properly maintained, monitored and charged, will have reduced capacity with every cycle. If the batteries have been abused, the capacity is further reduced. When new batteries are added to the old ones, the new ones have to work much harder to take up the slack of the reduced capacity of the old one, thereby hastening the reduced capacity of the new ones. Not only is it best to install the same brand, type and Ah ratings of batteries at the same time, all of the batteries in the installation should have the same date of manufacture, too. Granted, it's not all that critical in a truck installation, like it would be with really high dollar batteries in and off-the-grid situation, but it's still something to be aware of. By high dollar, I'm talking high dollar, like $500 or more for each 6-volt battery that, in pairs, gives 400 amp hours per 12-volt pair.
The Peukert Effect always applies. Whether charging or discharging, it's always there. A 100 amp hour battery with an amp draw of 5 amps gives you 5 amps for 20 hours. Not because 100/5=20, but because that's how it works out at 5 amps. The same battery having a 10 amp draw doesn't give you 10 amps for 10 hours. That would be too easy. What you actually get is 10 amps for 8.24 hours, and your 100 amp hour battery becomes an 82.36 amp battery.
Lower draws have the reverse effect, where a 2 amp draw off the same 100 Ah battery gives you not 2 amps for 50 hours, but 2 amps for 64.62 hours, and the battery becomes in effect a 129.25 Ah battery.
So you can see with that last paragraph how doubling your battery bank size will more than double your time, if your amp draw stays relatively the same after the upgrade. For example, a 40 amp draw from a 440 Ah battery bank (four PowerRush Group 31 batteries) works out to 40 amps for 9.3 hours, and an effective Ah bank of 372.18 amp hours. If you double the capacity of the bank to 880 Ah, then the same 40 amp draw yields 22.6 hours, not the simple doubling of 18.6, and the 880 Ah bank becomes 903 Ah to work with.
These hourly figures, again, assume you're running the batteries down dead, to where alarms sound, inverters squeal and stuff shuts down. 50% Depth of Discharge is where you want to be, so you really need double the amp hour capacity regardless, and of course a good battery monitor.
The Xantex TM500A is probably overkill, only in that it's designed more for multiple charging sources, like wind, solar and generators, and will keep track of how much power came from which source. It's nearly identical to the Trimetric 2020 in functions and performance, which is no surprise as Xantrex makes it for Trimetric. We have a Trimetric 2020 on the houseboat, or we did until we sold the boat. It works well enough. The performance and algorythms on the Xantrex LinkLite and LinkPro are more advanced and more accurate, however. But if you can get a 500A for that price, that's the one to get. There won't be that much difference between them. Basically all you want is a decent fuel gauge, something that measures amps in and out and calculate the current state of charge, and the TM500A will absolutely do that. It's a great monitor. So is the Victron BVM 602 (just in case anyone thought I get paid by Xantrex or something).
That 200 amp isolator should be fine. All the isolator has to do is be able to handle the amps from the alternator to the batteries, and you'll rarely get anywhere close to 200 amps. That's also why #0 cable is great for the isolator to the batteries. The longer the cable the more resistance there will be, which is why lager cable is required. You'll rarely send more than 80 amps down that cable, usually under 50 amps, and most of the time it'll be under 25, so AGW 6 cable will work. AWG 0 is the size to use to keep the voltage drop to 1%, assuming a 10 foot cable at 100 amps and 90° cable insulation. If you're happy with a 3% voltage drop (which I wouldn't be, but that's the standard), then AWG 4 cable is all you need. So yeah, #0 cable is perfect. 2/0 or larger would better, just to get that voltage drop down as much as you can, but there comes a point where the tradeoff between performance and price doesn't justify the price (which is why I backed off 4/0 cable and lugs and went with 2/0 cable hehe).
For the battery interconnects, if you've already got #2 cable on there, I'd stay with it rather than changing it all out, and not regret it for a second. But, for future reference, because of all of the multiple connections (cable to crimp, crimp to battery post, and multiple cables), larger cables should be used because of all of the opportunities for Ohm resistance to have an effect. In a critical or off-the-grid installation, the standard size for interconnects is AWG 4/0 cable. For anything under 12 batteries, AWG 2/0 cable will give essentially the same performance at quite a reduction in costs.
These large cables simply reduce resistance to the minimum possible. You can really and truly use AWG 4 cable for interconnects and the voltage loss will still be pretty minimal. You could even get by with #6 cable, but in a bank with 4 or more batteries, you would probably get a noticeable drop, minimal tho it would be.
The main thing is to keep all of the various cables the same length. Like, all of the interconnects, generally about 6 inches works well. If you use Method 4 above, then the cables that link each pair of batteries should all the the same as each other, and the cables that go to the installation should be the same as each other. Like the inverter cables, they need to both be the same length. The cables from the charging source don't necessarily have to be the same length for positive and negative, however, since in a 12-volt DC installation you have positive and ground, and the ground can be simply to the closest ground point, rather than have the ground cable the same length as the positive cable.
Scosche is fancy pancy alright, and it should work well enough. Be careful of the competition audio ANL wafer fuses that are so popular in audio installations, unless you know exactly what you're in for. There's a reason that a good ANL fuse costs $15, and a Class-T fuse costs $25, $30 or more.
Just so you know, even if you know already, someone out there might not....
ANN, ANL and Littelfuse CNL wafer limiter fuses are DC rated and are an economical alternative to the Class T fuses in a non-code installation with a small battery bank (as in 2 or 3 batteries). ANN, ANL and CNL are essentially the same, with some minor differences, and are usually interchangeable.
ANN fuses are rated up to 80 volts d.c. and 125 volts a.c. and have a maximum arc interrupt rating of 2,700 amps d.c.
ANL fuses are rated up to 80 volts d.c. and 32 volts a.c. and have a maximum arc interrupt rating of 2,700 amps d.c.
CNL fuses are rated up to 32 volts d.c. and and have a maximum arc interrupt rating of 2,500 amps d.c.
So all of these cover any voltage and amp requirements that we'd have out here on the road, since most are 12-volt and will be way under 2,500 amps in a short circuit situation. The arc interrupt means the fuse will blow and stop the current from arcing across the blown fuse in its attempt to re-complete the circuit, up to the amount of current that the fuse is rated for. If the amount of current is greater than the arc interrupt rating of the fuse, the arc will simply blow right past the blown fuse and keep on keppin' on.
Sooo, for those with more than about 3 batteries, where the CCA can exceed 2,700 amps in a short circuit arc, be very sure of what you are doing if you use an ANL fuse that won't stop a catastrophic short circuit.
The 400 amp ANN and 500 amp CNL fuses are popular for lots of uses, like truck winches, forklift applications, boat anchor winches, as well as for metal plating shops. Many people use these in their backup battery or standby power systems. Some inverter manufacturers recommend the use of an ANN, ANL or CNL fuse for overcurrent protection. But again, these usually don't involve multiple batteries where the total CCA is more than 2,000 amps.
Class-T fuses have a high arc interrupt rating and are specially designed to break and smother a direct current arc when the fuse blows.
Class-T fuses have an arc interrupt rating current of 20,000 amps D.C. and 200,000 amps A.C.
Code installations usually require a Class T fuse, not that a truck or a van is a Code situation, but it's something to be aware of.
The biggest difference from ANN, ANL and CNL fuses and Class-T fuses is that a these three fuses will break the circuit in short circuit current arc, while a Class-T fuse will smother it. And the Class-T will smother an arc up to 20,000 amps, whereas the ANN, ANL and CNL fuses can't stop an arc of more than 2,700 amps from just arcing right across a blown fuse.
If you go with ANL, you'll probably need ceramic ANL fuses, since they have higher amperage ratings. They won't have a higher arc rating to amount to anything, but they will be better than non-ceramic ANL fuses.
Remember to fuse for the size of the cable, and not for the expected amps that will be running through them.
14Wheeler
If you can sleep eat and watch TV , play with the computer and not hear or feel an engine running for 15 hours in 85 degree weather am I considered a green vehicle. Thankfully the Coronado had a mirror'd battery mount position for the oposing side of vehicle. The weight got evenly dispersed and the wiring met up quite easily for entry into cab. I took alot of time getting eveything buttoned up and took no shortcuts. Havent found a proper place to permanatly mount the monitor so its kinda dangling at the moment.
Of course the benifits of an 8 battery supply is just unreal. Thankfully my tax return check arrived just in the nick of time to pay off amex. Lotta money but still much less than installing a genset. I read and then re-read most of everything you wote combined with the propaganda from carrier.
Before, i always use to set the alarm for an 8 hour sleep. Even tho I knew I had more time on the original 4 batteries, I was always to nervous and always would run motor for 30 mins or so to re-boost. With 8 I do not even think any more about waking up and checking voltages. Sleep away and I do.
Outside of Phoenix last week and the temps during the day were near 90 for 11 hours. I had to park windshield facing the sun and still had no problem cooling the interior with little
to no effect on voltage reserves.. Unforunatly, when its time to replace the batteries, im faced with having to replace all of them at once. That is gonna hurt bigtime. Im seriously thinking im gonna put a huge $ dent in the return of this investment just in the next six months.
What size batteries? You are running 8? My 31 series batteries weigh about 70lbs each. 8 would then weigh 560lbs. That would knock off that much weight from your cargo capacity. Has that affected you yet?
