Tools (for the men)
pelicn
DRILL PRESS: A tall upright machine useful for suddenly
snatching flat metal bar stock out of your hands so that it smacks you
in the chest and flings your beer across the room, denting the
freshly-painted vertical stabilizer which you had carefully set in the
corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them
somewhere under the workbench with the speed of light. Also removes
fingerprints and hard-earned calluses from fingers in about the time it
takes you to say, 'Oh ....'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in
their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the
creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert
minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija
board principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to influence its course,
the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off
bolt heads. If nothing else is available, they can also be used to
transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the
conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch
wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile
upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than
any known drill bit that snaps neatly off in bolt holes thereby ending
any possible future use.
BAND SAW: A large stationary power saw primarily used by most
shops to cut good aluminum sheet into smaller pieces that more easily
fit into the trash can after you cut on the inside of the line instead
of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile
strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals
under lids or for opening old-style paper-and-tin oil cans and splashing
oil on your shirt; but can also be used, as the name implies, to strip
out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes
used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip
or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate the most expensive
parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines , refund checks, and rubber or plastic parts.
Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the
garage while yelling 'DAMMIT' at the top of your lungs. It is also,
most often, the next tool that you will need
;) :D
TeamCaffee
Wow Pelicn I know I am not a guy but wow could I relate to many of these items. I have always helped Bob in the shop and am very familiar with the items in the above post and how they react. I really had to laugh as I read each one and knew that at one time I have cussed almost every one of those machines. I cannot wait for Bob to get up and read this as I know he will also get a kick out of it.
pelicn
Oh yeah, me too Linda. Some of them I've done myself, others I've watched my hubby do....it's a laugh no matter what! :D
