everybuddy here know to the letter what i'm about to say .
HINO's are not for everyone , they are easily abused ,and need to be spec'ed to Expedite ,and treated well .most used Hino out there have being abused .
a simple test is to drive it ,and see the RPM at 60 MPH , if it is over 1,800 , than that is an abused truck ,it spent too mach time near the red line .
from what i see ,Hino made a big step forward with the new SCR engines .
if you will only change the rear ends ,before leaving the dealer lot ,and drive it slow ,it will the best investment .
if you cannot control your drivers ,those trucks will not last .they are not build to do 69MPH all day long at 2,300Rpm.
my Hino now have 230,000 mil . runs strong ,and almost maintenance free .
all of the few items that did bring the truck to the shop was either not 'Hino' related ,or things i bought on my self by not knowing the truck so well .
you can go to the Hino website ,where you will see for yourself the limited transmissions options . the Allison's auto ,will probably cost just around one MPG ,from what i hear ,but maybe not .
climbing up a hill never really being an issue .
if you are planing on a large inverter ,you will have to buy the Hino with the larger alternator ,and 3 deepcell battery's .
the bug screen is an option - get it !
the WV 'factory installed' seating is a bad joke at best ,almost as good as a joke as the windshield washer fluid location ,good luck installing an air ride passenger seat .
don't get cheap on the engine air cleaner ,buying the original will save your engine.
maybe some day we will get lucky ,and they will bring on the large cabover HINO from down under .
good luck in your new venture ,lets the attack begins ...
