Tire Pressure
rode2rouen
100psi is 100psi.
If it's cold outside, 100psi is 100psi.
If it's warm outside, 100psi is 100psi.
If the person meant that a tire with 90psi cold will read 100psi when warm, they are mistaken.
Rex
There is probably more like a 3 to 5 psi difference between cold and hot inflation pressures. It isn't the weather temp though it's the tire temp.
Leo Bricker, owner trucks 3034, 4958
OOIDA 677319
73's K5LDB
EO Forum Moderator 1+ Years of Service
Expediters Online.com - The Best is Getting Better!
Wilca2001
100psi is 100psi.
Rex
:mad: Rex, I guess you have never checked your tires after driving for a while. Why you think the manufacturer recomends checking the PSI when the tires are cold.
Was told 90 psi in cold weather is same as 100 in warm? Any thoughts would help Thanks
It is one PSI difference for every 10° F. So, if by "cold weather" you mean 20° F, and by "warm weather" you mean 120° F, then yes, your numbers are correct.
scottm4211
So you're running about 100 psi right now? :p
