I was just introduced to a new (to me) way of having my tires balanced. It is called a static balance. MAGNUM Tire Balancing Compound.
MAGNUM is a technologically advanced dry free-flowing compound designed principally for balancing medium truck tires, light truck and off-road tires, and custom wheels where wheel weights will mar the cosmetic appearance of the rims.
MAGNUM works with the rotation of the tire and wheel assembly. As the tire rotates, centrifugal force distributes the tire balancing compound evenly around the interior of the tire.
A heavy spot in the tread, or variation in the stiffness of the sidewall of the tire will create an equal and opposite force inside the tire that causes the MAGNUM to move away from the heavy spot in the opposite direction, thereby offsetting the effects of the heavy spot, and resulting in a perfectly balanced tire.
Has anyone heard of this product and how efective is it?
