Slo-Ride
Figured I would get this stated..
VENISON, How we fix it..
1 whole Deer,,De boned chilled & chunked to fit into your size grinder..(Keep back straps if ya want)
2 whole pork loins..(use 1 lb pork per 5 lbs venison)
1 package of breakfast sausage seasoning,,App 3 lb bag
Mix 1 tbl spoon seasoning per 1lb of meat into 1 cup water per 5lbs meat set aside and start grinding...Expample..10lbs meat =10tbl spoons seasoning,,2 cups water.. You can blend your own
seasoning but it will be real costly, buy it at your local butcher shop,,,Large bag...
Grind entire Deer & Pork on course grind,,Let meat fall right into a new cooler ya buy for this...Dont worry about any fat other the large chunks when deboning deer,,remove what ya can but no need to spend alot of time on it.
Mix in seasoned water mix it well though the course grind. Set up grinder on fine grind and run meat thu it again..
Package it into vacuum bags and seal bags (we go with about 1 lb bags)
Things to make this easy and fun :
At least 1 12 pack beer,,,2 helpers,,,1 new and large cooler with lid,,,,3 large mixing bowls for the chunked meat ,,,
Reason to get meat good and cold before ya start grinding is ya don't want meat to get warm during processing it..I mean get it chilly but not frozen..Its rough on the hands while mixing in seasoning,,,so who ever shot it mixes it...
Taste test it before ya start bagging it(grill up a few burgers),,add more seasoning and water if ya want,,But keep in mind flavor will get a bit better as the seasoning sets longer in the meat..receipe is just starting point,,ya can add more but ya cant take away seasoning,,go lighter if ya want....
This makes good Burgers,,lasagna meat,,spaghetti meat,,,great meat loaf mix(make up 3 or 4 small loafs last all week in the truck) and of course great breakfast sausage etc etc any thing beef burger this does better. For grilling burgers we mix in a bit of oatmeal,,seems to hold meat toghter a bit????
Clean-up: wash out cooler and large bowls with soap and mild bleach solution,,throw bowls in cooler and your ready for the next deer...Seasoning will stain the inside of cooler somewhat..dont worry about that, just make sure its cleaned and dry.Dedicate cooler and bowls just for this.
P.S. Add more beer if needed
