Expediter Services began a test on 3 Sprinter Vans.
Read their report here:
Sprinter Vans: Idle-Up or Shut Down? The Answer May be Both!
"Let's say you're driving a Sprinter van and pull into a parking lot, and place the gear selector into either "Park" or "Neutral" -- within three seconds, an alarm will sound inside the cabin."
Idle stick
Originally when I first ordered a 2011, there was a "high idle" and "variable idle" option available. The high idle was switch controlled. When on, the van would idle at 1800 rpms. The number 1800 couldn't get it verified. That's the number the dealer said, but wasn't 100% sure. The variable is what it implies up too 1800 rpms. There was no mention of the automatic shut down feature.
The price was somewhere around $600 for high and $900 for variable.
Vehicles ordered with ambulance, dog grooming or limousine pkgs included the high idle option. Yes there are specific use pkgs available for order. Of course that does not include finish out. Just options recommended for those uses. You won't find them on any web site. You gotta dig deep in the dealer manuals for the info and options included.
The problem I came across is not be able to find a dealer knowledgeable enough in special ordering these things that getting answers to specific questions on the pkgs was very time consuming.
For example, there are 3 different types of auxiliary heaters available. One of which is strictly engine preheat. The other 2, info was scarce.
Sent from my SCH-I605 using EO Forums mobile app
I am not a Sprinter owner but just wondering: Did MB drop the ball when they built an engine that doesn't provide sufficient oil pressure at idle? If so could a boost pump be installed that could bring the oil pressure to acceptable levels? Golfournut addressed my second thought. And lastly, with all this engine shut downs, are you going to have maintenance issues with dry starts? It seems like you would need a pre-oiler or additives to reduce/eliminate dry start related problems.
No one mentioned oil pressure?
Oh... Well bob was mistaken... We don't need idle for pressure ....that's not the reason...it is for heat and to keep exhaust cleared out.
The article in the open was about oil pressure.
Sent from my Fisher Price ABC-123.
BTW will the vans be red? --eb
If fleet ownership is the way of the future for sprinter vans then this switch will be useful. It protects the fleet owner's equipment by helping to control the habits of the driver. Owner operators will continue fighting the battle between idling costs and the weight of anti-idle solutions. It is interesting to see after decades of the No Idle fight that coming up with a way to idle is considered a solution.
Perhaps ES might help the cause by pushing the idea of a four wheel 3500.
eb
