2 years old today just put 119,200 miles,
in 3 day's put 1,300 miles on
running local is not easy 2
line haul is hard work
119k is a baby. I'm at 190k and looking to go hundreds more.
Make sure you follow maintenance intervals.
Oil, air, cabin, fuel filters,
frequent transmission, oil, and rear differential fluid changes and it will run forever!
Also keep some good diesel fuel injector cleaner in your tank, standodyne, liqui moly, redline, motul, power service, etc.
Synthetic Oil Changes 0w40 or 5w40 is best every 12-15k.
Don't worry about geo. He has a pretty good handle on Sprinters.
eb
due maintance and you won't end up on side of road
alway take care of things when there small
cause they only cost more when you have to fix them
Knock on wood, but I haven't had any DPF problems. But I also don't idle.
Bio WILL clog dpf filter!!...just two tanks did mine in....in a newer sprinter. I advise not using even a 5% mixture....
i have problems but with def system but at 80, to 90,000
but using ace's II kept these problem down
problem with bio diesel stanard's are not same each time they make it
they still don't have it right
mb say's don't use bio diesel yet
they have to get it better before i would even think of using it
