slack adjusters
TeamCaffee
To remove slack adjuster you will need snap ring pliers and a regular pair of pliers or vice grip and whatever adjustment tools you need to back off the brakes and probably a hammer.
First chock your wheels
release parking break
get under truck
back off (loosen) the brake
remove cotter pin through the clevis pin
remove the clevis pin
back off brake a little more to get the slack adjuster out of the clevis
remove the snap ring holding the slack adjuster to the S cam
remove the flat washer behind snap ring
slide the slack adjuster off of the S cam
reverse the process to reinstall
Some slack adjusters have two clevis pins a small one and big one and you must remove both. The clevis is that attaches the slack adjuster to the brake chamber rod.
bluejaybee
what am i missing here? how can a slack adjuster wear out. i could see them getting bent or damaged, but not wearing out. where is our friend piper with his simple words to explain this?
Desperado
if not properly greased it will I didn't start off with this truck new but with the offer to buy it at the price and interest even in bad times and a lot of work i can make it work
bluejaybee
I understand the "can make it work" part very well. Same thing I did. And am still doing. But I love grease! And the smell of Go-Jo.
theoldprof
A slack adjuster can show wear on the clevis pins and also the holes in the clevis that the pins go through.
