They are called super-singles or wide-base single tires. We did check them out and decided to go with traditional duals.
Super-singles are most often seen on trucks where the weight savings of the super-single setup can translate directly into additional freight on board; such as tankers where a few hundred pounds off the wheels can mean a few hundred pounds more freight pumped into the tank. I believe Wal-Mart is also converting its fleet to super-singles over time.
The decreased surface area of super-singles and stiffer sidewalls mean reduced rolling resistance and thus improved fuel economy. On an 18-wheeler, a super-single conversion would change 16 wheels into 8. On a 10-wheel straight truck, it would be 8 wheels into 4. Thus, the super-single benefits are less on a straight truck, which brings the cost of the conversion into question.
When we spec'ed our truck, meaningful data about the fuel-economy savings that super-singles may bring to a straight truck was not available. As far as I know, is still isn't. While we could have spec'ed super-singles on the brand new truck, and thereby saved the cost of conversion later on, we chose not to. Super-singles were still finding their way to market acceptance at that time. In the event of a needed tire repair out on the road, service for traditional dual tires would be easier to find. Super-singles are more available out there now, but not in all markets, like remote Montana and rural New Mexico, where we sometimes find ourselves.
The slightly-wider stance super-singles provide may provide a stability advantage in some straight trucks. But body roll is not an issue with our current truck, so that is not a reason to convert.
Someday, after the truck is paid for, and just for the heck of it, I might convert to super singles. I remain curious about the difference super-singles may make on a straight truck. They also look very cool (personal opinion of course). It would be interesting to run super-singles on our truck for a year and compare the drivability and fuel economy results to the year-before when we were running duals on the same truck.
However, based on the information now available, I do not believe the fuel economy savings would be enough to justify the cost of buying the new wheels that super-single tires require.
