PUT YOUR CAR KEYS BESIDE YOUR BED AT NIGHT
Put your car keys beside your bed at night. If you hear a noise outside your home or someone trying to get in your house, just press the panic button for your car. The alarm will be set off, and the horn will continue to sound until you turn it off.
This tip came from a neighborhood watch coordinator. Next time you come home for the night and you start to put your keys away, think of this:
It's a security alarm system that you probably already have and requires no installation. Test it. It will go off from most anywhere inside your house and will keep honking until your battery runs down or until you reset it with the button on the key fob chain. It works if you park in your driveway or garage. If your car alarm goes off when someone is trying to break in your house, odds are the bad guy won't stick around. And remember to carry your keys while walking to your car in a parking lot. The alarm can work the same way there. This is an idea that should really be shared with everyone.
Sometimes the best ideas are the simplest.
