setup for inverter
underdog777
Whats the best hook up for a battery and inverter. I would like To know the
battery type and model. And what size inverter you can use. I'm thinking of running a small tv. And and at times useing a small space heater. Any help would be great
Bruno
US Marines
We use a 2500 watt inverter in our trucks. You can find them on the web for less than $300.00. Some even tell you the best way to hook them up. We run heavy wires from the battery up to the inverter, then you can plug a power strip into the inverter to use your TV.
If your planning to run a heater with the truck off. Get a few deep cell marine battery's for the heater. Here is a link to website I found for you. 2500 Watt 24 Volt DC to AC Power Inverter
V3 Transportation
V3 Transportation
888-255-5955 ext. 3
Advertiser
Tractor Owner Operator Team
There is a thread on this very subject in the Tech forum- worth a look, some good info there.
You planning on having a truck full of batteries? If you are, then you can run the heater, otherwise think generator.
chefdennis
Greg is right, you will be either having a big load of batteries or replacing the ones (you notice i said one(s) as in more then 1) you have regularly...batteries will not live running a heater...
As Cheri said, the look in the Truck forum and look in the "sprinter" sticky for Turtles posts on this subject...and don't try to buy batteries that are "cheap" just to get by, there really is no "Cheap way" to get power into the truck....
Also, beyond the batteries and inverter for the house bank, you have to keep them charged also....that requires a good safe setup also...again, there is no "cheap way" to do this...read here in the suggested forums and threads, you will find the info to help you...Oh, the type and manufacturer of your truck will also dicate how this setup is done....
Well, you can run a space heater off of auxiliary batteries. All you need is, as Bruno said, a few deep cell marine batteries. Except, marine batteries won't really work, since they aren't designed for high amp draws, and "a few" becomes very subjective. But as long as you have a battery bank with enough amp hours in them, you can run a 1500 Watt space heater with no problem. How many batteries might that be, you ask? Let's do the math, shall we?
1500 Watt heater draws 12.5 amps at 120 volts, which inverts to 125 amps on a 12-volt battery system. Add in another 10% for the loss in the conversion from 120 to 12 volts, and it will draw 137.5 amps from the batteries.
If you want to run the heater for 8 hours, that's 8 x 137.5 = 1100 amp hours. Because you don't want to discharge the batteries below 50%, you need to double that to 2200 amp hours for the capacity of the battery bank. Because of the Peukert Effect, a 137.5 amp draw will actually require a battery bank of 2300 am hours, which will give you 2215.29 amp hours available.
L16 size batteries have about 410 amp hour each. They are 6 volts, so you need two for each 12-volt cell. 2300 amp hours divided by 410 amp hours is 5.60, rounded up to 6 batteries, so you'll need twelve of the 6-volt L16s in your battery bank.
Each of the L16s weighs about 125 pounds, so for twelve of them you're looking at 1500 pounds of batteries, plus the weight of AWG 2 cables and lugs and fuses, which will add about 100 pounds.
If your alternator puts about 30 amps back into the battery bank, after you've discharged 1100 amps out of them it will take approximately 47 hours to fully recharge the batteries, assuming you have no other amp draws off the batteries while they are being recharged. If you have cables large enough to handle the current, and a charging source capable of outputting a constant 150 amps into the batteries, then it should take only about 12 hours to fully recharge the batteries at 1100 amp hours.
Each of the twelve L16s will cost about $300 if you use Trojan wet cells, or about $500 if you use AGM batteries. So, $3600 for Trojans, $6000 for AGM. Add another roughly $280 for cable lugs, and $200 for AWG 2 Flex Cable, plus $300 or so for Class-T fuses and fuse blocks, heavy duty busbars and a master switch, and you're looking at either $4380 or $6780 depending on the type of battery bank you use. To run a space heater. The TV will hardly be noticed by the battery bank.
Seems like an awful lot of money to run a small space heater, not to mention the weight involved. But, to each his own. :D
Orrrrr, you would spend $300 on a couple of decent deep cycle batteries, hook an inverter to it, install an Espar heater, and run the TV and all sorts of other things for days without going near the 50% discharge depth.
V3 Transportation
V3 Transportation
888-255-5955 ext. 3
Advertiser
