Wasp spray with 50ft range is safer and better than pepper spray and their will never hear you pres the button!
If by "their will never" I assume you mean "
they will never," and by "they" I assume you mean wasps. If so, then yes, wasp spray is safer to use on wasps for self-defense than is pepper spray, and it's better to use wasp spray on wasps than it is to use pepper spray, and wasps will never hear you pressing the button on a can of wasps spray.
As for using wasp spray on people, that's just one of those things that seems logical because it sprays out in a stream like pepper spray and not like air freshener, so you can direct it like pepper spray, but that's where the similarities end. Wasp spray streams in a narrow stream that requires amazing accuracy to nail the eyes of an assailant immediately. Pepper spray has a very wide dispersal pattern, but still at a good distance (usually 10-20 feet) so that if sprayed anywhere in the general direction of the attacker it will be effective. Pepper spray also has a inflammatory that immediately forces the eyes closed whereas wasp spray does not. Pepper spray can "incapacitate an attacker for up to one hour, causes sever burning of the eyes with copious amounts of tears, coughing, and difficulty breathing. The eyes close involuntarily, the nose runs, and the skin stings."
Read the label on a can of wasp spray. It says wasp "spray causes minor eye irritation."
Read the label on a can of pepper spray. It says "pepper spray will **** you up."
