roof top for a cargo van
davidcal
Hello to everyone:
I need advice for buying a Roof Top for a Ford E350 Extended Van.
I checked with Millenium (too expensive) and you have to go to a distributor.
Any sugestions will be greatly appreciated.
By the way, I found some answers reading different posts.
Thanks in advance
Montero
guido4475
please let me know what info you find out.i am thinking about going into a van and want to go that route also.what kind/type of generator can i put on a van?
guido4475
i would not want to go that route with a cube truck because from what i understand is that the gvw is over 10,000 and it would require a logbook to run.and less fuel mileage, etc.
flattop40
Raising the roof does nothing for you unless you also change the doors.
If the opening for freight is the same you will get the same runs as I do without the raised roof but with alot of extra cost.
oncedrove
All Aerocell CW are built on a one ton cut away, which is the same as a one ton van, with a gvw of 9,600. The CW is not a dually. " Aerocell CW can handle heavy loads-up to 3,700 pounds"
once
Jack_Berry
Moderator Emeritus
